Haltech Difference between e6k and e6x?
Old Nov 22, 2005 | 04:08 PM
EvilWankel's Avatar
Knucklehead
Question Difference between e6k and e6x?
Is there any difference between the Haltech e6k and e6x? My e6k got stolen, and e6x seems to be easier to get now, so I was wondering if there is a difference, thanks.
Nick
Old Nov 22, 2005 | 06:56 PM
nik's Avatar
nik
Just incase you are wondering, you cannot use the K harness with the X ECU.
differences: The new E6X have built in map sensors. You can use halwinX with e6x. I believe there are more pwm outputs on the X, and it supports dual maps.
Old Nov 22, 2005 | 09:41 PM
87GTR's Avatar
is the datalogging any faster? K was 10 samples a sec
Old Nov 22, 2005 | 10:45 PM
Claudio RX-7's Avatar
EFI Tech Wannabe
The K and X harnesses are basically the same with a few wires that are different, you could use them if you take the time to check the different pins in each and wire accordingly. If you download both wiring diagrams from the Haltech website you could make it work. But BE CAREFULL!
Also, the X and the K are basically the same systems, with a few differences, like the dual map feature, the closed loop 3d boost control, windows software, now with the built in internal 2.5 bar/22psi map sensor, but theharness has the wires for the external if you want to run it.
Old Nov 22, 2005 | 11:24 PM
nik's Avatar
nik
In my datalogs, the time parameter goes to one decimal place, but the actual sample times vary, so approx 10 samples /sec.
Speaking of logs, has anyone been able to use the halwin datalogging? I find it terrible compared to DOS. It also doesnt support auto conversion of A/D to AFR (the dos does). This is as of 1.25, perhaps 1.26 is better.
Also, good to know about the harnesses. I was just going by what the haltech manuals said.
Old Nov 24, 2005 | 07:25 AM
-=Lil Red=-'s Avatar
R.I.P. Guitarjunkie28
im looking into buying a haltech right now. i was told to look for the e6k, but it is hard i have found the e6x. would any of u guys recommend i get the e6x?
Old Nov 24, 2005 | 12:07 PM
EFI Tech Wannabe
Yes, you should just get the X, its a very capable system with lots of options, and when configured right it can do a great job.
NIK, when datalogging with the X you need to previously select what parameters you want to log before you start it. After its done you can either use the graph viewer or open it with Excel.
Old Nov 24, 2005 | 05:48 PM
thanks, Claudio, i will look into getting the X.
Old Nov 24, 2005 | 08:53 PM
EFI Tech Wannabe
If you want one i can hook you up. I sell them for 1150 shipped with all sensors within the US. And you can payme via Paypal. (paypal 4% fee not included)
Let me know if you want one.
Shainiac
Jul 17, 2019 02:20 PM
Ian_D
Sep 6, 2015 10:38 PM
