Hot plugs and engine goes boom
Old Nov 20, 2005 | 11:10 PM
fecalfaced's Avatar
Newbie
Let's say you have a TII engine with S4 rotors. It's tuned to 11.5:1 across the board. You're running 17psi off a PT61. Advance is 13* and split is 10* at said boost level. Haltech E6X is controlling it. Plugs are the stock 7 and 9. You make a hard pull to 8000rpm. You lose the apex seals on the rear rotor. Intake temps at the time of demise at 135*. You happened to actually log the pull that did you in. Did the hot leading plugs do the engine in?
Old Nov 21, 2005 | 12:50 AM
Rotortuner's Avatar
Undercover
When the hot plug on the rear rotor was pulled, was the elctrode still intact? or was it gone?
CJG
Old Nov 21, 2005 | 02:19 AM
bcty's Avatar
Boost This!
i dont think that would do it unless like said above the electrode came off.. i ran sotck plugs on a modded engine as well and above 6.5K - 7K at full boost it would break up. i just backed off and its all good.. just make sure you run decent plugs next time.
Old Nov 21, 2005 | 09:24 AM
BNA_ELLIS's Avatar
yes the hot plug would seen it done a few times before.
Old Nov 21, 2005 | 10:03 AM
dubulup's Avatar
development
are S4 rotors 9.7:1? if that's the case...that seems like a lot of advance and boost for pump gas
Old Nov 21, 2005 | 01:55 PM
cewrx7r1's Avatar
Eye In The Sky
11.5 AFR at 17psi boost is too lean for street gas unless running WI, and 7 plugs are also too hot for over 300whp.
Old Nov 21, 2005 | 03:11 PM
zayrx7's Avatar
the mazda zoom zoom store
I've been running 20lbs @ 11.5 afr for 1 year no problem
Old Nov 21, 2005 | 04:19 PM
cewrx7r1's Avatar
Eye In The Sky
Street 92-93 octane without water injection?
Old Nov 21, 2005 | 05:25 PM
fecalfaced's Avatar
Newbie
Thanks for the comments guys. Keep them coming. The rotors are S4 TII rotors to clarify. We'd ran up to 19psi earlier without issues. But on 9s. The car is kind of a partnership effort and I didn't realize the plugs had been swapped for 7s until I tore the engine down. Just want to get a handle on why it detonated.
Old Nov 21, 2005 | 06:02 PM
zayrx7's Avatar
93-94 octane, no water injection
Old Nov 21, 2005 | 06:16 PM
FC3S.USD's Avatar
Where is my Life ?
S4 T2 rotors are 8.5 compression
Old Nov 21, 2005 | 07:36 PM
Rx_treme's Avatar
yes too hot of plugs can cause preignition.
Old Nov 21, 2005 | 07:41 PM
87GTR's Avatar
did you bouce of the rev limit?
Old Nov 21, 2005 | 07:52 PM
fecalfaced's Avatar
Newbie
Sure did. Pulled strong to the rev limiter. Large backfire at the limiter. Coasted down then when we eased back on the power to cruise it was on one rotor. The Haltech is set to ignition cut though. Think the limiter caused it? How?
Old Nov 22, 2005 | 11:45 AM
mazpower's Avatar
Slizzard sippin sizzurp
I wouldn't necessarily point the finger at the plugs yet. I ran 18 psi on a half-bridge FC, S5 9:1 rotors, 60-1 turbo, on 91 octane @ approx 10.8 AFR, with around the same intake temps. I was running 7s and 9s, stock ignition, and no breakup all the way to 8500. This was over a year ago, I sold the car and its still running fine @ 15 psi.
Old Nov 26, 2005 | 05:45 PM
RICE RACING's Avatar
100% YES.
Hot plugs will detonate a motor maybe not on the first pull but once she is loaded up you can kiss it good bye !
9's all round a bare minimum
10's if your serious
11's or higher if you make allot of grunt and are on it all the time.
7's and 8's or stock plugs and you or your tuner will learn the hard way about automotive spark plugs becoming diesle glow plugs in rotary engines.
Th0m4s
Feb 26, 2019 02:04 AM
alphawolff
Nov 17, 2015 05:57 PM
gtcd
30
Aug 19, 2015 02:44 AM
