Power FC Question about fuel maps for single turbos
Old Jan 25, 2002 | 06:42 PM
yy4u's Avatar
Hi i am running a FD with a greddy T-78 kit and everything else. High flow fuel pump, MP, DP, catback, FMIC, etc.
I also have a PFC and was wondering how different a map would be for my setup than the one posted by Jason for the single turbo settup with a T04s. Can i start out with this map and then do a little tuning or is that not safe.
Thanks for any info.
Old Jan 29, 2002 | 07:17 PM
Wargasm's Avatar
Weird Cat Man
I don't think the XS single turbo map is safe to run with your mods and here is why:
XS Engineering tunes the Basic Fuel Injection Map... the map you can tune and view with the Commander is the Fuel Correction Map. The map that is posted here is the Fuel Correction Map.
It is VERY likely that the XS Fuel Correction Map is only the "tweaks" on top of pretty significant changes to the Base Fuel Map.
If you try to run this, your car will explode in my opinion. Just my theory!
Brian
Old Jan 29, 2002 | 07:24 PM
Rotary93's Avatar
Retired RX7 mechanic
so what are you saying ..Have XS tune the PFC?
Old Jan 30, 2002 | 12:17 AM
RTRYPWR's Avatar
Newbie
So, Leave the Correction maps alone if you have XS tune the base injection maps your to your mods and only adjust the tweaks were needed.
If you have a non pre-tuned PFC, would you then adjust the Correction maps with the published maps?
Patrick
Old Jan 31, 2002 | 06:19 AM
Dragon's Avatar
20B N/A Wide Body FC3S
Patrick
If the map is from an XS tuned computer you should not use it on a your PFC period.. It will blow your engine... I'm pretty sure that XS rewrites the base map and then uses the correction maps to fine tune...
So if you run a XS tuned correction Map on a stock PFC w/o the base map that goes with it you will be without your car untill you come up with $ for a new engine...
Old Jan 31, 2002 | 09:41 AM
Rotary93's Avatar
So Dont use the PFC map # 5 on the forum?
Maybe Jason should take it down. Ill have to ask him about it....
Old Feb 1, 2002 | 02:15 PM
Jodeny's Avatar
Indifferent
The xs map has a very lean fuel map due to XS's reprogramming of the "base" fuel map.
The timing values are ok. If I was dumb enough to experiment with it, I would run a much richer fuel map and a little less timing and go from there.
J
Old Feb 1, 2002 | 02:28 PM
Rotary93's Avatar
Im going to suck up the 150 and get XS to tune my maps for me....along with the 3 bar sensor...
Engine Management Forum
11
Nov 9, 2015 01:15 PM
20B Forum
Aug 19, 2015 01:47 PM
