Microtech Microtech and FD's
Old Nov 18, 2005 | 07:07 AM
RedRX7R1's Avatar
Microtech and FD's
Anyone running a "Piggyback" microtech on their FD? Keeping the stock harness?
Old Nov 24, 2005 | 11:55 AM
73828793's Avatar
went RX crazy............
you mean using the harness adapter? if so i am using one currently.........
Old Nov 26, 2005 | 08:47 AM
G's 3rd Gen's Avatar
If ypor reffering to the plug and play adapter then yes.. It works fine..
Old Dec 15, 2005 | 05:53 PM
RedRX7R1's Avatar
Well I couldnt get the plug-in adpter with my deal so I wired directly into the factory harness. Lots of checking and soldering. I still have this stupid problem with my LT-8 and Home,rpm errors. Grrrrrr
Old Dec 15, 2005 | 10:34 PM
73828793's Avatar
did you calibrate the tps properly? can you provide a screen shot with the errors..........
Old Dec 16, 2005 | 01:54 PM
RedRX7R1's Avatar
Well I think I have found and fixed the problem...Not sure which of the two things though. I replaced a CAS that I put in a few weeks ago with another one(same part number-both check ok). The other thing was that when I first got the car 6 years ago I shimmed the CAS sensors so that they were closer to the wheel. They measured .426mm from the wheel. Well I took them out and remeasured the clerance and found out that they now are 1.1mm from the wheel (within factory spec 1-2mm). I took it out really quick since I'm at work no errors. we'll see.
Old Dec 18, 2005 | 12:54 AM
73828793's Avatar
keep us posted on if you indeed fixed the problem............
Old Dec 18, 2005 | 01:49 AM
Arvika's Avatar
Where can I buy it???
Old Dec 18, 2005 | 03:46 PM
flyboy02's Avatar
I'm having a CAS issue also, my ecu(LT10s) microtech is not getting a constant signal, i tried shims on the sensor, i switched sensors, ohm tested the wires, i even mailed the ecu back to microtech and talked to Maria in Aus. she said the ecu was fine no problems. what the hell is going on can someone help PLEASE!!!!!!!! It's only 3 or 4 wires going to the CAS and back to the ecu. Also I do have grounds on the car
Old Dec 18, 2005 | 03:48 PM
flyboy02's Avatar
by the way my car is a FD (sorry)
Old Dec 22, 2005 | 08:23 AM
Broken09's Avatar
I am becoming...
Although I thought I was following the wiring correctly I reversed two of the wires on the CAS the first time I hooked up my Microtech causing the same problem that you are having. You may need to reverse the wires in order to get a stronger signal. After I did that the car kicked on first try. Just a thought
Old Dec 31, 2005 | 10:32 AM
RedRX7R1's Avatar
Ok guys here is the update. After much driving and tuning I found out it was the claerance from the wheel that made the differance. Sorry to make this short adn sloppy (at work again). Make sure you have 1-2 mm from wheel. A closer look at what was going on... insted of clear wave signals from the sensor it was a constent high peak mess. So make sure it is with in spec. Hope this helps everyone with FD's.
Old Dec 31, 2005 | 11:03 PM
jamespond24's Avatar
Is there a diagram to wire it to an FD ECU?
Old Jan 2, 2006 | 10:37 AM
Arvika's Avatar
I would like an answer, please!
Old Jan 3, 2006 | 09:28 PM
RedRX7R1's Avatar
Buy what?
Old Jan 4, 2006 | 04:03 AM
Arvika's Avatar
Buy what?
the plug and play adapter!
Old Jan 9, 2006 | 09:28 PM
RedRX7R1's Avatar
I dont know.... I wired mine right into the factory harness.
eddierotary
Engine Management Forum
16
Oct 4, 2016 08:22 PM
frijol
Microtech
Sep 23, 2015 12:51 PM
freq
Haltech Forum
Sep 13, 2015 07:45 AM
