Can the Apexi rec/speed meter fit in a single DIN slot?
Old Jan 25, 2002 | 01:53 PM
Pouya's Avatar
This is the dimnesions of the unit (took me awhile to locate). 52 mm x 126 mm x 18 mm Does anyone know if I could fit this under a single DIN deck?
http://www.apexi-usa.com/meters_revspeedmeter.asp
Old Jan 25, 2002 | 02:30 PM
neo_omega's Avatar
***Moderator***
Pouya, you should know better than post this at the lounge.
Old Jan 25, 2002 | 02:57 PM
Pouya's Avatar
Ahh , indeed. I'll move it...
Old Jan 25, 2002 | 04:44 PM
neo_omega's Avatar
***Moderator***
I think AArotary has that. You may want to ask him.
Old Feb 1, 2002 | 09:51 AM
Yea that will fit! But I chose to mount it over my original tach. i used an piece of thin aluminum sheet with one mounting hole. i used the center screw at the top of the instrument guage bezel. I used a drill to make a small notch at the top rear of the bezel for the wire. I atached the Rev/Speed meter to the sheet aluminum with double back tape. I have room for bulbs for the rev indicator lamp and the speed indicator lamp which I just go trelays for. It covers the tach, mounted high so that it is easily visible.
If yoiu have any questions please reply to this thread.
check out the properties of this photo and paste the link into your browser to see how it is mounted.
TJ
Skeese
65
Mar 28, 2017 03:30 PM
Snoopy FD
Dec 8, 2015 01:45 PM
djritz
Aug 25, 2015 02:46 PM
