Nos Nos Nos, Pro's And Con's
Old Jan 25, 2002 | 03:11 AM
DC350's Avatar
Rotor Head
well, we all know the pro's for NOS in a rotary engine....but is it safe...i need alot of input for this one...anyways, thanks boys
Old Jan 25, 2002 | 03:31 AM
SirRX7's Avatar
Epitrochoid Knight/Mod
NOS should work as well as the other brands. Pros and cons should be similar.
Old Jan 25, 2002 | 03:57 AM
Node's Avatar
N2O or Nitrous Oxide, not NOS
like calling all rotaries a 13B-REW.
www.fc3s.org has some stuff about different setups of nitrous oxide. Both wet and dry systems
Old Jan 25, 2002 | 06:41 AM
sublimeracing's Avatar
As long as you don't over do it. A well tuned/running rx7 can take a 70-100 shot, with minimal wear to the engine. I've read that 13b's as classified with 6cyl. engines when it comes to NOS. The kits they sell are vehicle specific are the best because they are set up to not kill your engine...
Old Jan 25, 2002 | 07:00 AM
Josepi's Avatar
Despise Enmity
Beat me to it.
Pro: HP, cheap.
Con: Need a good fuel setup to make sure you don't lean out. Refer to the link that Node posted.
Old Jan 25, 2002 | 07:04 AM
The Ace's Avatar
Greek Power
Actually, I also remembered that NOS was N2O, but after checking the table, N has +3, +3,5, +4 and +5, while O has a +2 or +3 oxidization states, with 3 and 4 electrons in the outer 2p orbit. So their most common molecule should be N2O3...dont remember so...
Old Jan 25, 2002 | 08:03 AM
I wish I was driving!
Just out of curiousity, what are you talking about. Nitrous oxide is N20, not N2O3.
Sean Cathcart
Old Jan 25, 2002 | 09:51 AM
Gimpdiggity's Avatar
He's talking about molecular make up, but I don't know exactly what he's talking about.
Nitrous oxide is called N20 because it's TWO PARTS NITROGEN, AND ONE PART OXYGEN. If it was N203, it would be called nitrous trioxide. The whole Oxide part means it is a binary compound containing only one oxygen molecule.
Old Jan 25, 2002 | 09:58 AM
Sorry, forgot about the question at hand....
Pro of N2O - It makes your car fast.
Con of N20 - You have to refill the bottle when it's empty
Pro of N20 - You only have to use it when you want to.
Con of N20 - If two Asian guys on motorcycles shoot at your car while you're driving around with Dominic Torreto, your car will blow up...
But yes, check out the link that Node gave, that's where I found the best info about Nitrous Oxide on a rotary.
Jeff
Old Jan 25, 2002 | 01:52 PM
WET!!!!
Def get a wet system. My '89 vert rock with n230 or no5 or n20 or something. What ever it is the car is fast.
Old Jan 25, 2002 | 02:29 PM
jimmyv13's Avatar
Round&Round not Up&Down
Jeff
Old Jan 25, 2002 | 03:58 PM
FCRyosuke07's Avatar
thank you.. i cant stand when people call it NOS...it sounds so ignorant like "i-just-came-out-of-fast-and-the-furious-ish" i dont know if other companies make nitrous setups for the rx7's, but in my opinion NOS is the most low tech nitrous system out there. i would get a ZEX kit if there is one available for it. thats just me tho.
Old Jan 25, 2002 | 04:11 PM
Ryde _Or_Die's Avatar
Nitrous:
Pros:
1.Easy
2.Cheap
3.Makes your car alot faster
Cons:
1.Most people don't know what other mods to do to make it safe
2. " " " " " " " " " " " " "
3.See above
Old Jan 25, 2002 | 04:30 PM
cheap!!!
NOS #5132wet is a nice system, set at 3/4 throtttle and 4k RPM it is very easy to install and fun to drive. I also setup a turn off switch to kill the system during daily driving, to easy to get on it sometimes
Old Jan 25, 2002 | 05:53 PM
fastrotaries's Avatar
W. TX chirpin Monkey
RX7.com recommends Nitrous Express and so would i. those guys are dedicated to their work.........I'D HATE TO **** ANY ONE OFF BUT.... The industry has been referring to N2O as NOS for over 25 years. It's a slang term. So for all of you Engineer, PhD types on this forum, quit having a cow everytime someone calls it that. Yes - you know it's molecular structure, i'm so happy for you. Write it down, and give it to mom, so she can put it on the refrigerator
Old Jan 25, 2002 | 06:14 PM
amemiya's Avatar
Thats just because it is a house hold name like xerox. Its just easier.
Yelow RX-7's Avatar
Swingline Stapler
if it was me, i would go with Venom...
Old Jan 25, 2002 | 06:20 PM
DC350's Avatar
Rotor Head
hey
I dont really care about the molecular make up, i just wanted to know if NITROUS OXIDE f*ks over the rotary engines!!!! and is it safe over the long term, or what exactly happens?
Old Jan 25, 2002 | 07:32 PM
T2monster's Avatar
BRAP-BRAP-BRAP
I hate to bust alot of bubbles, but......you have to be more precise in using "NOS" to mean "Nitrous Oxide" in general, mainly b/c
NOS, Inc. is the largest manufacturer (not for very much longer) of nitrous oxide kits in the world and have been building systems since the late 60's. Personally, i think NOS brand kits are extremely well designed, mainly b/c they will not sell a dry system w/ more N2O than a stock feedback EFI system or carb. jet kit can accomodate for, and they sell wet kits that installed correctly are designed to hang the A/F ratio in a certain spot on the scale, a safe spot.
No, N2O will not make you spit apex seals, IF INSTALLED CORRECTLY, with additional good grade fuel. It is no harder on a rotary engine than intercooled turbocharging; they're both all a/b cylinder pressure.
'83 Limited
2100lbs.
drilled secondaries/stock carb
2.5" "free flow" exhaust
w/ Flowmaster and Gozanga tip (hehe)
'87 Turbo II
"Hybrid Theory"
RP 50mm turbo back exh.
GN 1600cc intake mounted boost
sensitive injectors (2)
Gutted turbo (no wastegate)
Custom boost reference voltage clamp
(thanx, teamfc3s.org)
Blitz xtreme air filter
Re-vaned S5 mass air
Boost, A/F, EGT guages
Alcohol cooled IC
Dual Electric fans
RB 6-puck bronze clutch
Old Jan 25, 2002 | 08:00 PM
PlayinW/Wankel's Avatar
Would N2O be easier on an engine because it is not used all the time, true that your not always running at max boost with turbos, but they are always forcing air into the engine. So wouldnt turbos be harder on the engine?
Actually Oxygen can have an oxidation state of -2. If I remember correctly in order for a element to be at the back half of a compound (i.e. the oxygen in N2O) it has to have a negative oxidation state, so with nitrogen having an oxidation state of +4, and oxygen having an oxidation state of -2, N20 would be able to occur. I think?? Correct me if I am wrong.
Old Jan 25, 2002 | 08:08 PM
RX-7Impreza's Avatar
I am the Anti-Ch(rice)t
NOS is NO5 that is why it looks like NOs on the bottle. the 5 is in subscript like in chemical equations. just clarifying. the reason Nitrous oxide is used is due to the large amount of oxygen it releases into the mixture. thus..... NO5
Justin
Old Jan 25, 2002 | 08:42 PM
That would make more sence because oxygen sometimes carries a 1- oxidation state, making a highly reactive element, that is also why it is used in oxy/acetalyne torches to increase the intensity of the flame. Metal shop and Chemistry all coming together
Old Jan 26, 2002 | 02:05 AM
NOS is NOT NO5...it's N2O. The numbers DON'T refer to the charge in the system, they refer to the NUMBER of molecules present in the compound.
Nitrous oxide is N2O, because it is 2 PARTS Nitrogen, and 1 PART oxygen...
It's BASIC chemistry, and not that difficult to follow.
http://www.webelements.com/webelemen...-10024972.html
Go there, it will show you that nitrous oxide is n2o. The CLOSEST compopund to NO5 is N2O5, which is dinitrogen pentoxide...hardly the same thing.
Old Jan 26, 2002 | 02:17 AM
The Vemon kit is nice just too pricey for me when i can do the same thing for less. Just remember one thing. It's not the N2O that makes the power. It's the fuel. Running Nitrous in your motor will only allow you the capability of running more fuel, thus the power increase. So without proper tunning you're pissing into the wind. Hence why motors go when under the influence of the bottle.
Old Jan 26, 2002 | 07:46 PM
DC350's Avatar
Rotor Head
OMG people
THIS THREAD IS NOT ABOUT THE MOLECULAR MAKEUP I WAS WONDERING IF IT IS BAD FOR THE ENGINE OR WHAT MAKES IT MESS UP! I DONT CARE ABOUT THE N20 AND THE N05, CHRIST
