Koni Yellows...
Old Nov 12, 2005 | 08:13 PM
MazdaTed's Avatar
Koni Yellows...
I have Koni yellows on one of my cars. and have a question about them.
If I leave them on the full stiff or near full stiff settings all the time will they wear out any faster?
Old Nov 13, 2005 | 09:30 AM
alberto_mg's Avatar
full stiff! damn! i had mine on full soft almost all the time.
whether its full stiff or full soft probably won't affect the shock's wear.
Old Nov 13, 2005 | 03:55 PM
MazdaTed's Avatar
WTF people on the other forus said that too. I dont get it, they are not that stiff.
I will try to see if I can stiffen the shocks up but pretty sure thats it.
Old Nov 13, 2005 | 06:37 PM
bcty's Avatar
Boost This!
ive been driving on full stiff for years.. just no worries now
Old Nov 14, 2005 | 08:58 AM
DamonB's Avatar
No. What wears inside a shock are seals and these see wear anytime the shaft moves. The damping won't change their rate of wear.
Old Nov 14, 2005 | 11:27 AM
MazdaTed's Avatar
I checked to see that they were on full firm and they were.
Do you think yours are stiff as hell?
Old Nov 17, 2005 | 02:04 PM
carsaregood's Avatar
how many turns is full firm?
also, fc-specific question: what does the install involve on those konis? I know some konis require some cutting/drilling/welding and interchanging with the stock parts.
do they have more than 1 groove for the spring perch ring for height adjustment? if so, how many? and how far apart are they? thanks!!
Old Nov 24, 2005 | 09:46 PM
MazdaTed's Avatar
Well, mine are on a miata. Since I was replacing the springs and mounts (for extra travel) it was really easy, exept on the front where I used the stock mounts which had a 10mm hole and the konis were 12mm (rear mounts came with 12mm hole already) fairly simple install scince I removedthe whole assembly and installed in a whole assembly. Mine have 3 grooves, stock (top groove), billistien (second grove), and some other name onthe bottome groove. Check racing beat they should have the shocks and all your answers.
Old Nov 25, 2005 | 03:08 AM
RETed's Avatar
Approximately 2.5 turns lock-to-lock.
Rears are practically drop in.
Fronts are another matter!
You need to "gut" a stock type stock, cause you need the bottom housing.
By drilling a hole of the bottom of that housing, the Koni strut is inserted and secure via a stud on the bottom.
No, you're thinking FD's.
FC's don't have this option.
-Ted
Old Nov 25, 2005 | 10:07 AM
MazdaTed's Avatar
FCs dont have that option? wow. You could take it to a machine shop and have them machine new grooves for a lower ride. Just be carefule that you dont lower it too much because you can kill all suspention travel and be losing traction because of hitting the bumpstops.
TomU
Jan 3, 2016 09:43 PM
ricardo.benin
Sep 22, 2015 12:06 PM
