Microtech what tps with microtech for a IDA setup?
Old Nov 9, 2005 | 10:30 PM
cwsttu's Avatar
1.3L is not that small
does microtech have a D shaped tps similar to haltech's ... or do i just buy a haltech and wire it up to the microtech? and also an aftermarket pressure sensor?
thanks in advance
Old Nov 10, 2005 | 09:23 AM
TwistedRotors's Avatar
Compression Tester Guy
The microtech will work with any 0-5v TPS. The MAP sensor is built into the unit.
-John
Old Nov 10, 2005 | 10:21 AM
cwsttu's Avatar
GREAT thanks i didnt know that about the map sensor.... thanks again ill look into the haltech D style tps and see if it works on that voltage
Old Nov 10, 2005 | 11:56 AM
No problem. And as far as I know, that Haltech is a standard GM style sensor (0-5v). These things are real common in junkyards. Back when I was running a Megasquirt I had 3 different GM TPS's that I got from a junkyard, all different styles.
-John
Old Nov 10, 2005 | 03:28 PM
cwsttu's Avatar
think i found one but the only place i can find it from is tweak-it.net... oh well ill have to order it along with my TB and manifolds
Old Nov 10, 2005 | 08:41 PM
FD Racer's Avatar
sold the FD...kept the FB
yeah the GM one works great. I recently got a spare one from the dealer just to have. I just said I had a LT1 Camaro...they had it in stock, it was around $60.
Here is a pic:
https://www.rx7club.com/forum/attach...hmentid=138702
Old Nov 10, 2005 | 08:51 PM
cwsttu's Avatar
wow nice to see somebody with the ida setup... what numbers are you making?
Old Nov 10, 2005 | 11:00 PM
1sgen's Avatar
583 rwhp 1st gen
i am using the one from microtech , it was like 75 aus dollar
Old Nov 10, 2005 | 11:58 PM
FD Racer's Avatar
Thanks.
I just recently had the motor out of the car on an engine dyno. I made 239 hp at 8000 and 166 torq at ~6000
I've been meaning to post my dyno sheet...I think I'll start a new thread though.
Old Nov 11, 2005 | 09:35 AM
SonicRaT's Avatar
Super Raterhater
There's a ton of us with IDA (or similar setups). You can find some TPS's on ebay for dirt cheap, rather than spending an armload on some of the others, that's where I got mine.
Shainiac
Jul 17, 2019 02:20 PM
freq
Haltech Forum
Sep 13, 2015 07:45 AM
