(IGNITION) MSD
Old Nov 8, 2005 | 08:19 PM
1badFB's Avatar
GSSL-SE
(IGNITION) MSD
Ok, I figure Im about due for some sort of ignition mod, so Ive decided to fork over the cash and get a capacitive discharge box over a 2GCDFIS or DLDFIS setup because I think the cdi box would be much more versatile and friendly to whatever mods I have to come. Im prety much set on a MSD 6A (unless someone can suggest something comparable). Now I think Ive got a handle on installing it, but my questions are: what kind of coils are the best to run with an MSD box? And where do you guys suggest I find one of these badboys up here in canada, preferably here in winnipeg? (they dont sell these at any ol' parts stores do they?) Also, just to clarify since Ive seen it both ways, I wire the coils in series rather than paralel, correct? thanks.
Old Nov 8, 2005 | 11:50 PM
OneRotor's Avatar
RAWR
I'd suggest Blaster 2 Coils to go with it. I have the coils, but not the box (bought it like this, working on getting everything else fixed before I up the performance any more), and they're strong as hell. I was checking to make sure that I was getting spark on my leading and trailing plugs, grounded my neck on my a-pillar while reaching through the window to turn the key, and my neck muscles were spasming for a couple of minutes. After i pulled that I made sure that my neck wasn't touching the a-pillar, and tried again (didn't see spark the first time because of the shock), and i'll be damned, my knee was on the door. They're crazy strong, it hurt worse than the time I got hit with 120V AC @ 60Hz (deadliest combination of electricity voltage and modulation). Check out rx7.com, rx7store.net, or something like Jegs. There is a writeup in the archives about how to install the box and wire everything up.
Old Nov 9, 2005 | 12:11 AM
Paradox's Avatar
backyard tuner
try using the stocker coils, see how it works. ive heard multiple stories of the blaster 2 coils failing, specially on our engines where they arent really meant to work at high rev's.
Old Nov 9, 2005 | 01:13 AM
Hyper4mance2k's Avatar
The Shadetree Project
https://www.rx7club.com/showthread.p...hlight=msd_dis
dona1326cosprings7
Oct 29, 2015 06:47 AM
eplusz
15
Oct 7, 2015 04:04 PM
GKW
Sep 28, 2015 04:34 PM
subeone
Sep 24, 2015 09:58 PM
