WTf??? Wtf??? Why me????????????
Old Jan 24, 2002 | 03:50 PM
NVMYRX7's Avatar
Unhappy WTf??? Wtf??? Why me????????????
ok here's the problem guys and girls.........i grounded my ECU just fine today and then i grounded the boost sensor(brown wire with white stripe) i ran the boost sensor ground from the wire to the bracket that holds the factory air box down just to the left of the boost sensor>>>>>>>>>>then i tried to start the CAR AND it would just keep cranking and not turning over!!!!!>>so then i un plugged the boost sensor ground from the bracket and it fired right up????/ WTF is up?????? did I run the ground to the right place or what???? I need some help bad!!!!!!!!
Please Help if you know how to do this the right way!!!!!!!!!!!!!!!!!!!!!!
Thanks
Josh
Old Jan 24, 2002 | 07:47 PM
HAILERS's Avatar
HAILERS
WRONG WIRE. Should be the brown wire with a black stripe.
t-von
Sep 10, 2015 01:56 PM
EfiniGirl
Haltech Forum
Sep 1, 2015 09:31 PM
Wolf_
Aug 11, 2015 04:23 PM
Ryde _Or_Die
Oct 30, 2001 01:48 AM
