Exhaust Going On Next Week!!!
Old Jan 24, 2002 | 01:36 PM
Gimpdiggity's Avatar
Hey everyone!! After reading and reading and searching and searching I FINALLY have my exhaust ready to be put on my 1986 N/A.
I spent TONS of time looking through old threads, and asking questions about exhausts, and I wanted to thank everyone for their patience and help with a newbie like me.
Here's what I've got going on, probably on Monday or Wednesday of next week. I'm going to be putting a Mindtrain header, and Mindtrain presilencer on. I'm going to be getting custom mandrel bent pipe from the cat back to a 5Zigen Fireball muffler. I think I'll be running it down the passenger side, to try and offset the driver's weight a little bit.
I'm also going to be performing the throttle body mod, wiring open my 5/6 ports, and doing an ATF treatment (even though my compression is okay, I figure it can't hurt.)
Is there ANYTHING at all that you guys would suggest to help me out?? Should I do these things in any specific order, or doesn't it really matter??
Once again, thanks alot.
Jeff
Old Jan 24, 2002 | 01:51 PM
Yelow RX-7's Avatar
Swingline Stapler
all i request is some pics when you are doing it and when it is done. Good Luck.
Old Jan 24, 2002 | 01:52 PM
I'll try to get as many as I can, but be warned, the body of the car isn't the greatest right now...body work is next though!!!
Jeff
Old Jan 24, 2002 | 01:59 PM
mazdaspeed7's Avatar
mad scientist
Do the ATF trick with your old exhaust on. It can clog up presilencers. Other than that, sounds like a plan.
Old Jan 24, 2002 | 02:02 PM
Thanks for the tip Mazdaspeed!!! I would've messed up then, because I was gonna do it AFTER I got the stuff on, but now I won't have to worry about that part!!
Jeff
Old Jan 24, 2002 | 02:10 PM
rico05's Avatar
WTB S5 N/A FC
If you are removing cats and 5th and 6th ports, go ahead and remove the air pump! Also, wire the VDI open. It is definatly worth the pain in the *** it is to do!
Old Jan 24, 2002 | 02:11 PM
I forgot about that Rico, I was planning on taking the air pump and the a/c off too!!!
Jeff
Old Jan 24, 2002 | 02:25 PM
MaxRX7's Avatar
hambre y sueño
VERY nice choice !
1st park the car where you want it to sit for atleast 24hours. then take out the O2 sensor and start the ATF trick. After 24hours, turn the sucker on and clear the smoke, put in new plugs once it cools. By that time the exhaust will be cool and you can put on your new exhaust.
I REALLY recommend a lift or be ready for a sore back if you'll be working on the floor.
Old Jan 24, 2002 | 02:32 PM
I know Max, my friend's father is an ASE master mechanic, and runs his own shop, so we'll be going over there to use the hydro lift, I'm not gonna try and be all sore when it's done from crawling around under the car!!!
Jeff
Th0m4s
Feb 26, 2019 02:04 AM
Jutta_J
Mar 25, 2017 11:24 PM
85TIIDEVIL
Aug 25, 2015 12:09 AM
