overheat and security lights
Old Jan 24, 2002 | 11:56 AM
puma's Avatar
canadian monster
are these usefull?
is there anything bad in removing them? don't ask why, just tell me if they are usefull or if i can get rid of that. (I will have a EGT guage)
thanks a lot
puma
Old Jan 24, 2002 | 11:42 PM
puma's Avatar
canadian monster
anybody?
Old Jan 24, 2002 | 11:48 PM
skunks's Avatar
I'm a CF and poop smith
i learned that they cost 80-90 bucks each and thats for a little peice of plastic and a super small bulb, what a friggen rip off!!!
Old Jan 25, 2002 | 12:59 AM
maxcooper's Avatar
WWFSMD
I replaced the light bulb in my security light with a similar part from a Miata. The Mazda parts guy could not find a number for the RX-7 light, but recognized it as being similar (it wasn't exactly the same) to one from a Miata. It has worked fine for over two years now, and only cost $3 or so.
I don't see any harm in removing these -- they are just indicator lights after all. You won't know when the factory alarm is on, or if an exhaust system overheat is detected, but that probably isn't a big deal. The exhaust system overheat is pretty basic anyway -- it just measures the temp in the floor above the exhaust system. Presumably it only goes on when the main cat gets clogged or some other condition that would probably have other obvious symptoms.
The PowerFC uses the exhaust system overheat light to indicate other conditions, though, like overboost and possibly other things.
-Max
Old Jan 25, 2002 | 05:24 AM
skunks's Avatar
maxcooper, could you tell me what light you used from the miata, was it the dash light or something like that?
Old Jan 25, 2002 | 06:23 AM
CantGoStraight's Avatar
What's your point ?
Replacement lamp for security
I looked in my service manual and found that the lamps for the foglamp illumination, and exhaust over temp and security are of the same wattage. I found a dirrect replacement at radio shack and did not have to buy a new one from the dealer. I'll have to look and see if I can find the number again as i let it in a post on this forum some time back. It's not hard to take the indicator apart and remove the lamp and replace it. It is however very small. If anyone has concerns about doing it them selves I'd be happy to do it. Just send me the indicator and I'll install the lamp and send it back...cost would be shipping and cost of the lamp. This also goes for the rocker switches (fog lamp, or defroster)
risingsunroof82
22
Sep 22, 2015 01:20 PM
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
The1Sun
Sep 7, 2015 10:21 PM
