fd + rsr racing + koni yellow 5way sport
Old Nov 6, 2005 | 03:19 PM
sevensix's Avatar
rotor rotor pow.
hello. im thinking of getting the above setup on my 94. are there rubbing issues running the setup with stock wheels and 245 rubbers and the konis set on the lowest ride height? looking for people that have this setup! and pictures.......
thanks in advance
Old Nov 6, 2005 | 06:29 PM
Mahjik's Avatar
Mr. Links
With the Koni's on the lowest perch setting and the RSR Race Springs, you'll probably have rubbing issues. The RSR Race Springs apparently lower more than the advertised heights. At the normal perch setting, the RSR Race Springs are about the perfect height.
Not my car, but a picture of a car with those springs on stock shocks:
As you can see, any lower and you'll have problems.
rynberg's Avatar
With the Konis, the fronts must be set on the highest spring perch or you'll annihilate your fender liners. The rears may be set to the lowest without issue, if that balances the ride height better.
Old Nov 6, 2005 | 07:04 PM
turbogarrett's Avatar
0 lbs of boost
I have koni's with rsr race springs. I have them set at the highest perch all around. No rubbing and a great all around setup. Tires are 235/40, 265/40 17's.
Old Nov 7, 2005 | 02:10 AM
sevensix's Avatar
rotor rotor pow.
im starting to think i should have gotten lower profile tires... instead of 245/45s. just saw a few other people mention rubbing with konis as well..
i'll get it set up in the next few weeks.. and report back on how it is.
i really don't want the front much lower than stock.. maybe 1/2 inch, back im hoping to get at least a 1.25 drop
Old Nov 7, 2005 | 03:05 AM
rynberg's Avatar
First of all, 245/45 is the proper size for stock or other 16" wheels. People run lower profile tires when running larger diameter wheels.
Secondly, there are NO rubbing issues with the Konis. They are not meant to be used on the lower perch settings with lowering springs....my ride height is quite even (although too low) with my HKS springs and Konis -- fronts on highest perch, rears on lowest perch. Hopefully, I'll finally get a chance to install my Zeal B6s soon...
Old Nov 7, 2005 | 08:18 AM
Rxmfn7's Avatar
Do a barrel roll!
Old Nov 9, 2005 | 05:27 PM
ManGaZeRo's Avatar
Living the Dream
If it will rub with rsr race springs won't it definitely rub with koni and eibach pro kit?
Old Nov 10, 2005 | 02:54 PM
xurotaryrocket's Avatar
If you set the Konis to the highests perch setting they will basically be "stock" height. Then with the RSR's on it will lower the car. You will be fine.
Now, if you use the lowering springs AND put the Konis on the lowest setting....then you're screwed.
Old Nov 11, 2005 | 11:12 PM
omochi's Avatar
fd-withdrawal
if you plan to run eibahc+koni.. i'm using the highest in the front, lowest in the back w/ no issues.
Old Jan 10, 2006 | 09:10 PM
sevensix's Avatar
rotor rotor pow.
i picked up some rsr race and gab super r's
