Help me pick the right FD LSD
Old Nov 4, 2005 | 10:45 AM
turbogarrett's Avatar
0 lbs of boost
Long story short, a local shop has lost my '87 t2 lsd and manual fd companion flange that I dropped off with an auto fd pumpkin for assembly. So now I am considering a kaaz or other aftermarket vs. picking up another s4 t2 lsd.
I drive the car on the street on a regular basis, dragstrip, attend a couple hpde weekends and autox's per year. Which one would best suit my "jack off all trades" type of car? If I do go with a kaaz etc., what % lockup would allow me hard launches at the strip and smooth cornering at the roadcourse?
thanx for your time, Garrett
Old Nov 10, 2005 | 02:02 PM
jagwrjack's Avatar
You might want to test drive a car with a cusco/kaaz before you go to the trouble of installing one.
Sounds like you'll make the same use of your car as I do.
I have the cusco/3;90 in my FD/LS1 and have been considering removing it. It's a 2-way and really makes a horrific clanking noise around corners.
I wanted to track the car but the car wallows around long sweeping turns when the rear is between locking and unlocking. I put in new diff bushings (stock) so I don't think that's the problem. I'm using NEO gear oil.
Just food for thought. Too bad your in Wis. otherwise you could check my setup out.
Jack
Old Nov 10, 2005 | 05:47 PM
0 lbs of boost
Yeah, ^ that's what I'm worried about, have you tried removing any of the plates?
Now I am having a helluva time tracking down a t2 diff. The jimlab cobra cradle is looking better every day!
Old Nov 10, 2005 | 06:32 PM
Eagle7's Avatar
I've got a turbo lsd.
http://www.i2k.com/~mdoane/ForSale/PartsForSale2.htm bottom of the page.
As noted, the companion flange has been removed and modified, and I don't have first-hand knowledge of the diff condition. Feels smooth and tight. If you're interested I'll make you a deal.
mdoane@i2k.com
Old Nov 10, 2005 | 06:45 PM
0 lbs of boost
mdoane@i2k.com
Let's make a deal, emailed ya.
