S5 dash into S4 Questions
Old Oct 31, 2005 | 03:49 PM
NOPR's Avatar
Rotary Apprentice
Basically, i got ahold of a free S5 black dash to replace my maroon-turned-brown dash and I'm wondering what the easiest way to swap it will be. Should I just rip out all of the electronics from the S5 and swap the 'shell' of the dash since I'm doing this for cosmetic purposes only?
Also, the S5 has a different redline for the N/A's if im not mistaken (if they're both manual)? so could i take that guage cluster? are there any other series differences i should be aware of if i decide to switch anything else like the wiper motor or turn signal or cruise control or something? thanks in advance
Old Oct 31, 2005 | 03:54 PM
KompressorLOgic's Avatar
I
basicly the easyest way is to just swap the coloured dash board it self , and reuse all the old electronics from the s4.
you can swap a s5 gauge cluster into your car fairly easily, there will be some rewiring required as the wires that plug into the back of hte cluster are in different locations. there is a write up on it somewhere if you search for the conversion.
Old Oct 31, 2005 | 04:13 PM
WhoDiddy6's Avatar
i've searched for the write up, no luck.
Old Oct 31, 2005 | 04:18 PM
I
well i found it searching on the internet instead of the forum search feature lol...
this is for swaping a s5 na 5sp gauge cluster into a 5sp s4 na
https://www.rx7club.com/2nd-gen-archive-72/gauge-cluster-swap-pins-again-s4-wires-s5-cluster-285724/
here is a write up by icemark
no pictures but ohh well... basicly it looks like you need to move all the wires around to fit the list he wrote
_Tones_
May 25, 2021 05:37 AM
Nosferatu
Sep 5, 2015 02:13 PM
