Wierd stuffs going on
Old Oct 29, 2005 | 08:24 AM
bigdaddyp's Avatar
Ok, hello everyone I have a question mabey you guys can help me with. I have an 86 rx7 GXL. When I crank the car sometimes, only happened 3 times since I got the car about a month and a half ago, it will be beeping, no lights on or anything, just be beeping. When I start to back up, it will be really hard to steer for a few seconds, then it will get easy to steer, and it will stop beeping, I checked, and it has enough power steering fluid, any suggestions would be greatly appreciated, thank you in advance.
Old Oct 29, 2005 | 09:05 AM
KompressorLOgic's Avatar
I
the beeping you here means something is wrong with the power steering.... how many beeps is it in a row?? it will go like beep beep beep....pause beep beep beep..... or somthing like that
theres 5 different "beep codes" the ps will throw. 1-5 beeps
Old Oct 29, 2005 | 09:55 AM
herrafass's Avatar
if you can't figure out what code it is throwing, try loosening the belt and spinning the pylley on the front of the PS pump. This is to check the berring. If it's no good you'll know.
Old Oct 30, 2005 | 07:19 AM
bigdaddyp's Avatar
ok, thanks for help, next time it beeps I will count them.
Old Oct 30, 2005 | 10:00 AM
Icemark's Avatar
The beeping information is found in the FAQ for FC Sticky thread found at the top of this, the second gen RX-7 section
Old Oct 31, 2005 | 12:15 AM
HOZZMANRX7's Avatar
Driving RX7's since 1979
Thumbs up Icemark, you're a savior once again
Where do you find this information. I just spend the evening going through my Factory Shop Manual, and nothing like this could be found.
Good stuff.
Old Oct 31, 2005 | 03:26 PM
pek2gianne's Avatar
Newbie
can someone help me find the "beep codes" mine also beeps. 3 consecutive beeps then a pause then another 3 consecutive beeps is what im getting in my TII. thank you
Hank
Oct 1, 2015 07:34 AM
