Clutch lines.
Old Oct 27, 2005 | 09:58 PM
FirstRotaryExp's Avatar
The Brap is Back
Clutch lines.
I just purchased and brought home my 89 GXL today. I had to trailer it home but in the few tiem sI had to move it she smoked somethign awful when the clutch was depressed. I mean, acrid awful nasty stuff that came up from the shifter and from under the car. I saw some spots of liquid that was where the car had been when I moved ehr so I do think my clutch line(s) are leakign or have holes in them. I was wondering if this could cause my clutch to slip and is it an wasy process to replace them?
Old Oct 27, 2005 | 10:00 PM
AcidShock's Avatar
Eet fase
Low clutch fluid I do not think will directly cause the clutch to slip. It will, however, prevent you from disengaging/engaging the clutch. The lines are not hard to replace they are accessible on the driver's side on the firewall. If a lot of fluid has somehow seeped down onto the clutch itself THAT would cause some slippage.
Old Oct 27, 2005 | 10:02 PM
The Brap is Back
yes that was what I was thinking...since the fluid is burning and the car is not leaking anything else. The clutch seems to engage very late and i have to keep the revs up to nearly 4 grand to get her to move a bit, in first or reverse. I will be getting a clutch kit as soon as I am able to so that is another question, what is about the right set to use for a stock S5 N/A?
Old Oct 27, 2005 | 10:07 PM
AcidShock's Avatar
Eet fase
Just go with the OEM disc and pressure plate. It has worked this long, it must be decent. If you want to go aftermarket, the ACT S/S kit is a good one as well. Make sure that your kit includes a new throwout bearing, pilot bearing, pilot bearing seal, and alignment tool.
Old Oct 27, 2005 | 10:10 PM
The Brap is Back
Yeah I knew I was going to need those, since Ill be doing that to my 88 SE as soon as I get my other upgrades outta the way....But I cant do any work to it until the 89 is running right. but so far the motor is up to snuff, she purrs all the way to 8 grand and has very little smoke at startup...well...little for sitting for a year and a half.
rodney87's Avatar
http://www.srmotorsports.com/sr86clch.html
That's where I'm going when I get the money
Old Oct 27, 2005 | 10:14 PM
The Brap is Back
my wallet cries at the sight of those prices....but if it has to be it must be...was lookign forward to a parts car though...oh well.
Old Oct 28, 2005 | 01:25 AM
swiftfc's Avatar
this might sound extremely dumb but when u guys say u need tranny fluid is that the same as clutch fluid?
Old Oct 28, 2005 | 01:40 AM
jono20's Avatar
clutch fluid is brake fluid.
are you sure you slave cylinder on the tranny isnt leaking?
Old Oct 28, 2005 | 01:45 AM
dantheman_94080's Avatar
i think he was asking if tranny fluid is another name for clutch fluid? or vice versa
if so no, tranny fluid and clutch fluid are 2 seperate things
Stanello's Avatar
backslash beanbagrace
^--- what jono20 said.
If you're replacing the clutch line, I'd go with this: http://mazdatrix.com/getprice.asp?partnum=4990
$18 stainless steel clutch line.
Old Oct 28, 2005 | 01:58 AM
swiftfc's Avatar
k thnx a bunch guys i found that out by reading aarons mcguiver page on a ghetto tranny pump which actually looks pro imma drain the clutch fluid and the tranny fluid next friday. jono i do see a couple dropps of oil =( and ever since i've notice that it gets pretty hard to shift when the car is cold but when its warm its easier than when its cold but its still not smooth. do u think its my slave cylinder? if so how much would it cost? thnx
Old Nov 3, 2005 | 08:19 PM
swiftfc's Avatar
any ideas?
Old Nov 3, 2005 | 08:33 PM
The Brap is Back
well I have figured its the slave thats leaking, but until i can afford to monkey in ther i have to let her sit for now. THanks for your help gentlemen, though now i wonder if its possible to do the work with the motor in the car...
Old Nov 3, 2005 | 09:40 PM
AcidShock's Avatar
Eet fase
What do you mean with the motor in the car? You can absolutely change the slave cylinder with the motor in the car. All you need is 1/4 rachet, an extension, socket, and maybe a universal joint.
Old Nov 3, 2005 | 10:23 PM
The Brap is Back
lol...sorry...ive been braindead since 6am, thinking hasnt been done since last week. But I couldnt for the life of me remember if I had to pull the block out to change the slave cylinder, since I couldnt remember if there were fittings in teh bellhousing.....'runs to other thread where he documented some of his first engine swap for the 88)
Snoopy FD
Oct 13, 2016 06:12 AM
risingsunroof82
Sep 9, 2015 08:06 PM
