Can the Kosei rims be powder coated?
Old Oct 27, 2005 | 12:13 PM
JessicaR's Avatar
I'm gonna paint my 7 black and the interior is gonna remain brown, so I figured I could buy some Kosei rims and powdercoat them a metalic gold or even black.
Old Oct 27, 2005 | 12:36 PM
Rogue_Wulff's Avatar
Too old to act my age
Well, since they come finished in silver, I would say they could easily be powder coated any color you want.
Old Oct 27, 2005 | 12:52 PM
JessicaR's Avatar
Thank you Wulff...i think i'll purchase a set sometime this month!
Old Oct 27, 2005 | 01:22 PM
If you powder coat your rims, you will not be able to race on any tracks. I know here at Texas World Speedway they will not let you pass tech. Too many powder coated rims have failed.
They like to break compleatly apart at the rim. The baking process aparently weakens them.
Old Oct 27, 2005 | 01:47 PM
JessicaR's Avatar
My rx7 is a daily driver. I don't really have plans for taking it to a track. Maybe I might take it to a 1/4 mile strip, but that would be the extent of it.
Old Oct 27, 2005 | 02:39 PM
skrewloose78's Avatar
Anti-rice Superstar
this for the most part is true.
standard powdercoating requires a cure temp of around 425 f. aluminum starts getting weak around 350-400 f. which will permanatly damage the rim. you can however podwercoat aluminum with a "low cure" powdercoat that only requires being baked at 285-300 f. . any decent powdercoater should know this. check with the local sanctions to be sure that your rims will pass tech.
Old Oct 27, 2005 | 03:43 PM
JessicaR's Avatar
I'll look around and probably purchase a set anyway (seem to be the only ones that are available for 7's anyway), if I have any doubt I'll leave them as is.
Old Oct 27, 2005 | 05:17 PM
evil_motors's Avatar
Slide Or Die
also i would have your car checked out first because black shows every little imperfection ... so make sure you do some really good body work
Old Oct 27, 2005 | 08:38 PM
Rx7carl's Avatar
Airflow is my life
Whew glad you guys clued her in on this. I wont PC wheels cause I dont have the powders yet for it.
23Racer
Canadian Forum
13
Nov 25, 2018 04:44 PM
Rotary12Ahead
Oct 29, 2015 03:16 PM
NickNac113
13
Oct 1, 2015 09:25 PM
