Electric Fans?
Old Jan 23, 2002 | 08:17 AM
jsinrx7's Avatar
Electric Fans?
Hey guys! what do you guys think about an electric fan in a 79' street driven RX-7? has anyone run into problems? is it worth it? and if so any recommendations? I heard on here I think that the 90' Taurus fan fits nicely. If anyone can help me I would really appreciate it. Thanks, Jason
Old Jan 23, 2002 | 08:40 AM
Steve Shulz's Avatar
I got one from Schucks (go online and print out the price, its usually 10-15 $ cheaper) I then removed the crappy *** clutch fan and shroud, hooked it up and away I went. I wish I would have gotten the adjustable thermo switch, but you get used to turning it on and off. One of these days I will wire it into my AC switch. There are threads out there about people using fans off of other cars, just do a search.
Old Jan 23, 2002 | 10:32 AM
rotorhead's Avatar
lots of folks use the 'black magic' fan with good results. check summit racing. www.summitracing.com
Old Jan 23, 2002 | 01:27 PM
peejay's Avatar
Old [Sch|F]ool
you want the biggest fan you can find (not just the biggest you can afford) and if you have the '79-82 setup with the large oil cooler under the radiator, make it so the fan overlaps the oil cooler a good amount.
Old Jan 23, 2002 | 08:06 PM
I custom made mine from a pontiac fiero, it fits my radiator and goes accross most of my oil cooler. This fan was designed for a car that has a V6 in the rear so cooling off a rotory WILL not be a problem!. Mine is also on a toggle switch but im also gonna wire it up to the a/c switch. When drag racing i just used it right before the burn out box and on the way back to the the pits. When autocrossing i had to leave it on all the time, but the motor was at 7000rpms most of the time.
Old Jan 23, 2002 | 09:11 PM
jsinrx7's Avatar
Hey thanks for the replies everyone! you have helped alot! Will running an electric fan free up a noticable amount of HP? Thanks again, Jason
Old Jan 24, 2002 | 08:33 AM
minute hp gain, you figure without the drag of the clutch fan you would but the extra load to the alternator will take it back; however when driving I have my fan off completely and only use it when in traffic and things get heated up. My clutch fan was so bad it would send cyclic vibrations down the shaft and I could feel it in the seat. Have fun on your conversion.
Old Jan 24, 2002 | 11:24 PM
jsinrx7's Avatar
Hey 81dragrx7colorado, I got a fan from a Fiero GT today from the junkyard and man does if fit the Rad like a glove! I am soo happy with it, I cant wait to hook up the electricals tomorrow. I looked at Taurus fans while I was out there, and I have to say the Fiero unit is superior. and for 30 bucks you cant go wrong! Only minor mods were required to mount it on my 79 Rad, and it actually looks factory! I will post pics tomorrow. Thanks again everyone! Jason
Old Jan 25, 2002 | 12:02 AM
peejay's Avatar
Old [Sch|F]ool
there is a bigger HP gain than you would think... a clutch fan pulls more CFM than an electric, so it needs more energy to turn.
Car Craft did a test on all sorts of different fans, from a stock (for the engine) non-clutch fan (450hp) all the way up to no fan at all (496hp). A clutch fan in working condition was 485hp, and with an electric fan on it was 494hp. so on that engine a clutch fan in WORKING condition sucked 11hp, an electric fan only sucked 2hp, and a non-clutch fan sucked 46hp. I think that engine only revved to about 6000rpm too.
My '80 had a clutch fan that wouldn't freewheel easily, it was stuck in "hot" mode. You could feel the difference like night and day just by loosening the belts so the belts would slip at high RPM. This sucked for belt life but at least the engine didn't have a ton of HP sucked away.
Basically if you're serious about performance you need an electric. Also if you remove the air pump an electric is almost mandatory to prevent slipping/breaking belts all the time.
Old Jan 25, 2002 | 05:57 PM
Viperx7's Avatar
I've got twin 10"s on mine. They fit perfectly in between the radiator supports and produce 900 cfm apiece. Haven't had any problems with cooling.
Old Jan 25, 2002 | 06:35 PM
serf2's Avatar
For any of you guys that need a fan control. There is a company called Centech here in Pa. They sell the neatest fan control. It wires to the fan and gets its signal from either the sending unit on the engine or to the back of your gauge in the dash. It has a control adjustment so you can set the temperture when it will kick the fan on. I have installed a couple of them on street rods and they work very well. I have not put one on a Rx7 but I am sure they will work just as well. I can't remember the cost but if you contact them they are very helpful and nice.Info # 610-754-0740, or www.centechwire.com. They also sell wiring kits for many applications.
