misfiring
Old Oct 22, 2005 | 08:24 PM
3rd and final 7's Avatar
wheres the water goin?
misfiring
i just got home the other day and i used the block weld fix and it was runnin fine and i out everyting back together and its misfirin its fine if i speed up lowly and then it will start ro misfire. i put a fresh pkug in and it ran fine for a while and it started back again i know my o2 senser is bad abd not hooked up i dont know what it could be. it was arcing over at my coils and i fixed that and its stilll misfiring if someone could me pls it would help
Old Oct 22, 2005 | 08:36 PM
K-Tune's Avatar
FD Daily
are all 4 plugs firing?
Old Oct 22, 2005 | 08:39 PM
i beleive so i ll have to cho in the morning but coud it be anything else
Old Oct 23, 2005 | 08:07 AM
all 4 plugs are firing they dont look that strong but i dont know how to tell
Old Oct 23, 2005 | 09:08 AM
FB II's Avatar
ok i'll try to make some sense out of this. ????
you welded your block? i'm lost, either way you say it's fine if you slowly accellerate but then up top in the high rpms it starts to misfire again. did you remove your distributor at all?
Old Oct 23, 2005 | 10:09 AM
i just got in from pullin the distributer and when i did the insides fell apart the points (i know its electrontic egnition but it looked like points to me) i added some pics too im going to need a new cap too joy
Attached Thumbnails misfiring-pa230077.jpg   misfiring-pa230076.jpg   misfiring-pa230075.jpg   misfiring-pa230074.jpg
Old Oct 23, 2005 | 09:08 PM
brandon davis's Avatar
That would be a problem.
Old Oct 24, 2005 | 03:06 PM
Kentetsu's Avatar
Yeah, that's your rotor. Get a new cap and rotor and you should be golden.
alphawolff
Nov 17, 2015 05:57 PM
R7rexy
19
Sep 2, 2015 10:24 AM
rxmiles
Aug 24, 2015 02:07 PM
Wolf_
Aug 11, 2015 04:23 PM
