Diff problem?
Old Oct 22, 2005 | 01:22 PM
Shane79's Avatar
Diff problem?
More torque is going to my right wheel than my left. I can tell because it's always the first one to break loose in the wet and I can even feel it try to turn the car to the left on a hard one two upshift. I wanted rear wheel drive to get away from torque steer! Any ideas?
Old Oct 22, 2005 | 01:26 PM
evil_motors's Avatar
Slide Or Die
how about a limited slip diff..
Old Oct 22, 2005 | 10:22 PM
Rusty Shackleford's Avatar
****ty Tune= Low #'s
i swaped a rear from a gsl in and did a drift event and burnouts so im sure i got an LSD but one night when it had rained and found a really really sweet group of turns into a new unopened neighborhood..i kept going in and out and never once drifted any of the S-turns in there because only my inside tire would spin...so...idk if i have a problem too or if you need more load in order for the diff to lock and make both tires start spinning??
Old Oct 22, 2005 | 10:28 PM
kevinbtz's Avatar
Shell 93
what type of diff lube did you use?
ZacMan
Sep 19, 2015 09:20 PM
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
