anibody with the a-spec gt35R with the t4 hot side? opinions
Old Oct 20, 2005 | 08:12 PM
13bmaniac's Avatar
hello lookinf for opinions of the kit reliabylity,quality setups with this single kit.
hp, torque and how many hp produce at boot leverls of 15 16 psi
thanks
i own a t-78 greedy full kit but still looking to know ifo on this
Old Oct 20, 2005 | 08:33 PM
vel525's Avatar
Woo Hoo, It Runs!!
not trying to be an ***, but there's been a lot of discussion on this turbo already. try a quic search and also, check out a-spec's section. they've listed a lot of detail on the 35R and their other turbos. good luck.
Old Oct 20, 2005 | 09:06 PM
BoostedRex's Avatar
NorCal 7's Co-founder
Broken09 would be the best person to talk to since he owns one. I can speak on how high the build quality of the kit/manifold is. First rate quality with good customer service. If I remember right Broken09 put down 436rwhp at either 15 or 16psi. That's about as much help as I can be. I would check out A-Spec's sub forum in the group buy area if you are interested though.
Zach
Old Oct 20, 2005 | 09:25 PM
Broken09's Avatar
I am becoming...
It's a great kit. Zach got the numbers right it made 436 at 16psi. I have 16psi by about 3500 rpm, and that's on a damaged turbine wheel. You won't be dissappointed if you buy the kit. Feel free to get ahold of me if you have any specific questions.
Old Oct 21, 2005 | 10:28 AM
I have this kit as well and the quality is first class! Just be prepared to wait awhile for it....also there is a few tricks to the install that would make it alot easier....granted the problems I experienced in my kit are probably all fixed now considering mine was the first one made.
Old Oct 21, 2005 | 11:58 AM
Zero R's Avatar
Just in time to die
Lol, yes they are all worked out. But it is still a little tricky near the turbine/water fitting area. (not a lot of room). We have a few options available. You can check on the link below to get whatever you need to know. Waiting is no longer a issue at the moment as I have supply for now, it is demand I am having a harder time keeping up with. Plus part of Hydoukens wait was development.
https://www.rx7club.com/forumdisplay...sprune=2&f=154
Skeese
65
Mar 28, 2017 03:30 PM
apooch
Aug 23, 2015 10:31 AM
immanuel__7
Megasquirt Forum
Aug 22, 2015 09:34 PM
Clacor
Aug 14, 2015 09:17 AM
