repairing ssr rs8
Old Oct 20, 2005 | 08:55 AM
Muffet's Avatar
repairing ssr rs8
hi, I want to repair my ssr rs8 rims (more than repair them, clean them, repaint them, etc) and i have a problem. I removed the 16 bolts of the rim and the 2 pieces are still together.... there is another thing that i have to do to separate them?
thanks
Old Oct 20, 2005 | 10:05 AM
RETed's Avatar
Usually glue'd or some kinda sealant...
-Ted
Old Oct 20, 2005 | 10:17 AM
DamonB's Avatar
Go after 'em with a rubber mallet.
Old Oct 20, 2005 | 12:38 PM
BC-FD3S's Avatar
I am also disassembling my Work VS-SS. I took out all the bolts and the center disk still stuck. Try hammer it with rubber mallet and it still won't seperate. Anyone has suggestion how to remove it?
BC
Old Oct 20, 2005 | 01:06 PM
Cheers!'s Avatar
Former Rx7 *****
I think the rim shells and the centres are shrunk fit together.
Meaning they place the wheel shell on a rotary table and then heat it with a propane torch. Then they drop the centre in and bolt the two peices together....
Old Oct 20, 2005 | 02:15 PM
Quickfini's Avatar
My 2 piece Works are getting repaired now too actually and the guys there said they had to use like a silicone sealant or something along those lines.
Old Oct 20, 2005 | 10:29 PM
BC-FD3S's Avatar
How do you manage to disassemble the wheel? Mine is a 3 pieces with the lip and rim welded and center disk bolted.
BC
Old Oct 26, 2005 | 10:44 PM
BC-FD3S's Avatar
Finally I am able to dissamble my Work wheel. I have to use a block of 2x4 wood and hammer out the center disk. After couple hits at every corner, the disk comes off.
BC
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
izzolaw
1st Gen General Discussion
Sep 27, 2015 08:33 PM
