***please Help Me With My Gsl-se!***
HI I WAS SEARCHING FOR ABOUT AN HOUR AND FOUND NO REALL ANSWER.... MY QUESTION IS IF ANYONE KNOWS WEATHER THE ROTA RB WHEELS WILL FIT MY CAR
HERE IS A LINK!
http://gtmwheels.com/product_info.ph...e1b0dd5048c3f8
I KNOW THE BOLT PATTERN IS RIGHT BUT IM UNSURE OF HOW THEOFFSET WILL FIT.......
WILL IT STICK IN OR OUT? ARE THEY GONA RUB? WILL THEY EVEN WORK AT ALL>?
WELL IM WHEEL FITMENT CHALLENGED SO ANY ONE THAT CAN HELP THIS RX-7 NEWB PLEASE DO LOL..... I JUST GOT IT LAST NIGHT AND ITS MY FIRST 7
ALRIGHT GUYS THANKYOU FOR ANY HELP IT WILL ALL BE APRECIATED
HERE IS A LINK!
I found this, search in the tire/wheels/suspension section https://www.rx7club.com/showthread.p...ghlight=offset
Cpa7 And Smn Thank You For Your Replies And The Search!
But To Smnc Or To Anyone Else For That Matter That Might Know The Answer To #2
1. I Want Them For The Track Lol
2. They Wont Fit How In The Front? Are They Going To Rub On The Inside Or Are They Going To Stick Out?
Because If They Are Going To Stick Out Its Ok Since I Will Be Able To Slap On Some Cp Racing Fender Flares To Take Care Of The Problem If Thats The Case.
Trending Topics
Originally Posted by FBDrifter
lower number means the wheels will be further from the springs.
Though after some measuring, it MIGHT sqeak in there.... Depends on your springs and tires...
13" wont fit SE brakes under them..you need at least 14"
really are you sure they dont fit over se brakes? damn it
...... i could have sworn someone in here on the forums has 13" rims on there se....
but a lower number means the will stick out then? would that be ok then with some cp racing fender flares?
...... i could have sworn someone in here on the forums has 13" rims on there se.... but a lower number means the will stick out then? would that be ok then with some cp racing fender flares?
They'll stick out no matter what. 7" is about the largest that will fit in the stock fender...
The question is if they'll clear the springs...
If you go with front coil-overs, I'd say yes.
With stock springs it'll be tight... I'd say probably yes, but you might need a small wheel spacer...
I dunno about fitting over the brakes tho... I've never thought about putting a 13" rim on there...
Certified Old Fart
From: Inkerman, On, South of Ottawa, the 2nd coldest Capital in the World
There's another guy on the forum who's got a gsl-se, and said that he got the rota rb's. His screen name is something like "Rhino61" I think. I never heard how it worked out though. I wouldn't use them for anything but autox/track days. I'm pretty sure they fit though. They just stick out past the fenders a ways. The important thing is that they fit over your calipers. You will have to run some very small diameter tires also. Like 215/50/13's or 225/45/13's. These usually only come in "r" compounds, and aren't meant for the street.
NickNac113
13
Oct 1, 2015 09:25 PM
