Underdrive pulley
Old Oct 18, 2005 | 07:52 PM
Eriks85Rx7's Avatar
Wheel Revolutionist!
Underdrive pulley
Once again im lookin for some cheap mods haha well i went to rx7 .com I found this under drive pulley and read somewhere it give up to 8hp? Is this true are they a good thing for the price of 75$ Underdrive pulley
Old Oct 18, 2005 | 08:36 PM
ApG Spaz's Avatar
Gen 1 4 life
a bit more appealing in price than this set.. http://www.mazdaracing.com/pulleysystem.asp
course this has all the pulleys and a belt..
Old Oct 18, 2005 | 08:42 PM
rbf41182gt's Avatar
sounds good to me. I'm probably gonna pick up a dual belt alternator pully soon
there's a set on ebay once in awhile, and i think they claim 15 hp.
Old Oct 18, 2005 | 08:58 PM
rbf41182gt's Avatar
yeah, that's the one on ebay
10-15 hp sounds pretty good, but it's not all that cheap
Old Oct 18, 2005 | 09:00 PM
aussiesmg's Avatar
Thunder from downunder
Beware of twin pulleys they cause squealing as you never have two equally tight belts.
Old Oct 18, 2005 | 09:01 PM
Midwest 7's's Avatar
sellout
15hp gain is bullshit. take out your airpump and ac and you might gain a couple hp.
Old Oct 18, 2005 | 09:02 PM
Eriks85Rx7's Avatar
What about the one on rx7.com my car still has A/C and Powersteering. How much hp/ torque could i expect to gain by gettin the pulley?
Old Oct 18, 2005 | 09:07 PM
rbf41182gt's Avatar
only a couple, i'd say
yeah, actually, idk how reliable/ accurate Mazda Racing is- "If your like 90% of the Rotary world and run your engine at 8500 rpm and higher, you NEED this system." LOL!!
Old Oct 18, 2005 | 09:23 PM
inuissus_cendi's Avatar
haha 15hp? out of an engine that makes just over 100hp stock? no way. the only possible way they could claim that much would be on a massive turbo/high boost setup (cause your N/A power is basically multiplied with boost, so a few horses gain N/A would multiply with boost)
the thing that would really improve with underdrive/lightweight pulleys is response, since the engine will rev more freely. same thing when you remove the air pump.
so i would say its not really a bad upgrade, but i think that 15hp is an unrealistic claim.
Old Oct 18, 2005 | 09:24 PM
Eriks85Rx7's Avatar
LOL
Old Oct 18, 2005 | 09:49 PM
aussiesmg's Avatar
There are a lot of parts out there that aren't worth much, you'd be better off looking at removal of unnecessary parts as previously said, this also costs less.
Old Oct 18, 2005 | 10:13 PM
fcdrifter13's Avatar
Play Well
From: We're all fine here now, thank you. How are you?
Under drive pulleys arnt exactly made to make power. They were first made to underdrive the water pump so at higher revs it wouldnt cause cavitation(im pretty sure that is the correct term) in the cooling system. It also slows your Alt speed so if you dont run at high enough revs it will cause a slight discharge in you battery.
Old Oct 18, 2005 | 10:18 PM
Play Well
Now Erik if your looking for quick cheap power for when we race down at Kanawha Valley. I may be able to sell you my carb and Racing beat intake for the cheap. Just get that pump I was talking about and youll be good to go. Or you should get a header. If your worried about emissions in this state they just do a visual. If its all there then they slap on a sticker. And if they cat do it at your house ill get the sticker from the garage.
BTW you still aint gonna touch my GTU, but hey remember its all still bracket racing you may still win.
Alex Saunders
Old Oct 18, 2005 | 10:21 PM
Eriks85Rx7's Avatar
haa well talk to me on aim a today or tomorrow and give me a price on your "intake" so i can smoke you gtu at the track
Old Oct 19, 2005 | 11:39 AM
mooseknuckle's Avatar
i need a 20b in my fb
that stuff doesnt "add" any horsepower just frees up the hp that it takes to run it after u remove it.
Old Oct 19, 2005 | 05:04 PM
mikey D's Avatar
man im glad someone else said it first
That **** doesnt give HP
it is reciprocating mass.
if you lighten it then less work is require to turn it!
just like a flywheel or a lighter set of wheels and tires.
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
Robrods64
Oct 2, 2015 07:56 PM
Turblown
Sep 30, 2015 05:58 PM
