The entire interior is going in tomorrow, and I need help by then...
Old Oct 16, 2005 | 09:58 PM
$100T2's Avatar
On the prowl for an FB
I am wiring my fuel pump to a solenoid to be controlled by a kill switch. What is a good wire to splice into that is only on when the ignition is on? I would rather NOT tap into the power to the radio. Any other suggestions?
Old Oct 16, 2005 | 10:25 PM
REVHED's Avatar
Hunting Skylines
Run the power straight off the battery. You can use the coil positive to trigger the relay through the kill switch.
Old Oct 16, 2005 | 11:17 PM
Paradox's Avatar
backyard tuner
why not just use the stock 12v source for the fuel pump? i did this for my kill switch, works fine.
Old Oct 16, 2005 | 11:27 PM
FB II's Avatar
yes sir, that's what i did as well.
Old Oct 16, 2005 | 11:34 PM
vipernicus42's Avatar
Rotoholic Moderookie
Ditto that. The fuel pump wire is an ignition-on wire. On '84-85s it has the one extra provision that the engine be running/cranking. Should be fine, and right where you need it.
If you can't find that, I'm not sure!
Jon
Old Oct 16, 2005 | 11:36 PM
FB II's Avatar
yea and also on those 84/85's you can bypass that because it suuuuuux
Old Oct 16, 2005 | 11:46 PM
REVHED's Avatar
Hunting Skylines
Yeah you can use the stock wiring to trigger a relay. Just depends where you want to position the kill switch and relay as to whats easier.
Old Oct 17, 2005 | 07:59 AM
$100T2's Avatar
****. I forgot to mention, the stock fuel pump wiring isn't acceptable because it's not working, hence me needing to rewire it. I don't want to wire it straight to the battery, because I would like to limit the amount of **** at the terminals. I would like to find something under the dash that is unused.
