new rx3
Old Oct 16, 2005 | 07:29 PM
squagles's Avatar
new rx3
hi i just picked up a nice shape rx3 coup.
its a 73 with a gslse engine and tranny. i need info on how to upgrade the suspension and the brake system.can anyone link me or give me some insight into what can be used?
thanks tyler
Old Oct 17, 2005 | 02:15 AM
Matt22's Avatar
Fear The RE
how about some pics.
Old Oct 17, 2005 | 10:18 AM
Crit's Avatar
No distributor? No thanks
For brakes, go to respeed.com and you can fit GSL rear discs to your axle. A 81-83.5 LSD will also drop into your pumpkin (NOT a GSL-SE - you have to find one with threaded holes on the input flange. Check for 81-83 with rear discs and take that chunk!!). Scott's Old Auto Rubber (www.scottsoldautorubber.com.au) in Australia is the only real source for new bushings, door moldings, bailey channels (the felt inlays that your glass slides up and down on) and stuff like that. You can copy the old Racing Beat Stage 1 kit (talk to ReSpeed again for those) to slightly relocate your front sway bar so it won't induce a caster change under cornering. There are no straightforward front brake upgrades yet, but you can do it with enough motivation.
And yeah, post some pics.
Old Oct 17, 2005 | 03:53 PM
Doc Holiday's Avatar
Needs more cow bell
I have a front brake upgrade kit on my 72 RX3. All new aluminum hubs, 4 piston aluminum calipers, and large drilled rotors. TheRacingStore.com sells them. Call Tony. Bolts right on.
Old Oct 17, 2005 | 06:22 PM
squagles's Avatar
how much for that front brake kit? i think ill be getting those plates for the rear brakes to put the gsl disks on.
anyhow ill have pics of the car put up in a day or so.
Old Oct 19, 2005 | 01:59 PM
squagles's Avatar
gsgle carbed ned answers
so i have a few questions about my motor setup. I was replacign a alternator belt yesterday and i noticed that on the distributer there are two little vacume things wich i think are for vacume advance of the spark but there not hooked up.
so here is the setup its a gslse engine with a 12a 4 barrel carb on it (i think 12a it looks like the carb on my brothers 84 gs.)
now i already think the setup is wrong because its a smaller carb on a bigger motor so i was thinking about either getting a holly or getting the nikki carb sent and made into a sterling carb. So what do i do about the advance on th 13b motor.? does it need to be vacume advanced or does it need to be electronically advanced?
and as far as the carb goes what should i get and what size ,its stock ported and it has a racing beat header and full exhaus.
thanks tyler
Old Oct 20, 2005 | 02:34 PM
squagles's Avatar
pics of the car
anyone about thst motor question?
Old Oct 20, 2005 | 02:43 PM
Crit's Avatar
Sterling would actually be a good guy to ask about jetting a Nikki for a 13B. The advance mechanism only advances the timing under vacuum, and hence is for street driving and off-idle performance. Most folks just disconnect it, set the advance for high-rpm, and let it sputter a little at low-speed. If you want to hook up the advance diaphragms go for it, but most people don't. RX-4, RX-5 and REPU had 13Bs with Hitachi or Nikki carbs (depending on the years) so it's possible that you have a 13B carb, but there are bazillions of 12A Nikkis, so it will probably need to be rejetted. Carl and Sterling to great jobs with carbs, so I'd refer you to them for a Nikki.
Old Oct 20, 2005 | 02:48 PM
squagles's Avatar
pics
cool thanks here are some pics
Old Oct 20, 2005 | 07:32 PM
Crit's Avatar
Damn, that's a really clean 3. Good find.
Old Oct 20, 2005 | 07:45 PM
Matt22's Avatar
Fear The RE
Very nice. and its such a cute shade of baby blue. JK rx3s are pretty sweet.
Old Oct 20, 2005 | 11:43 PM
islandsnow's Avatar
Nice find, very clean
Old Oct 21, 2005 | 04:03 AM
re10's Avatar
10a *****
Same colour as mine, nice choice!!!
Old Oct 21, 2005 | 04:36 PM
nigel20b's Avatar
Webber Powered
nice ride man ... my cousin got one here in Toronto,ontario
Old Oct 22, 2005 | 10:21 PM
P-nut's Avatar
I Dont Think Thats A 6port Or Do You Have An Adapter For That Intake
Old Oct 22, 2005 | 11:16 PM
squagles's Avatar
then guy i bought it from said it was a gslse motor so mabey it has a adapter im not 100% sure.
Old Oct 24, 2005 | 11:02 PM
P-nut's Avatar
I Could Be Wrong But I Never Seen A Carburated 13b 6port Manifold Like That.i Really Cant Tell If It Has A 4port Too 6port Adpter In That Pic
Old Oct 26, 2005 | 10:54 PM
squagles's Avatar
ill take a pic of the carb closer up tomoro
