Fuel system questions
Old Oct 13, 2005 | 10:30 PM
viperkiller7's Avatar
1.3 liters of whoop ass
I want your feedback on what pump to use. here are the 2 im lookin at.
Aeromotive A1000 600lbs which i know most people use. or should i get the aeromotive eliminator which is 800 lbs per hour. Before you answer here is my setup.
1990 T2
13 B re cosmo motor ported yes ported
Upgraded T78
720cc primary inj.
1600cc sec.inj
-10 braided will go from tank to the pump
-8 from pump to yblock
-6 from y block to each rail
-6 out of rails to reg then -6 return
also going to use the sump from summit
Im going to run around 20 psi but as high as 30.
Im using a micrtech ltx10s with a 3 bar map
Let me know if you think the basic a1000 wil work or i should go bigger just in case. thanks in advance for your input.
Rodney
82streetracer
Aug 23, 2015 09:28 AM
