Power FC Removing Airpump and PFC
Old Jan 21, 2002 | 10:38 AM
KZ1's Avatar
KZ1
With the PFC, do I need to do anything when removing the airpump. My understandign is I just need to disconnect the connector and voila. no plates, resistors, etc.
can someone confirm this. I want to install my greddy pulley kit tonight.
Thanks
Philip
Old Jan 21, 2002 | 11:30 AM
cewrx7r1's Avatar
Eye In The Sky
When I do my AFR runs, I only disconnect the wiring plug from the pump and all runs fine. I still leave the O2 idle control on as it seems to
idle smoother.
Just pull your pump and test which idle control function gives you the best idle. Nothing else to do.
Old Jan 22, 2002 | 10:32 AM
I've disconected my air pump and I've had to pull quite a bit of fuel out in the idle ranges or the car would stumble all over its self.
Old Jan 22, 2002 | 10:33 AM
Flybye's Avatar
It's never fast enough...
Mine idles the same with or without the airpump connected, and I never noticed anychange when running it.
It's wierd. It's just like with the stock ECU. Some FDs idle fluctuates with the airpump disconnected and some dont.
Old Jan 22, 2002 | 09:34 PM
FD Racer's Avatar
sold the FD...kept the FB
Mine idles well with it on or off too. However, my o2 sensor voltage drops from .80-.85v to like .00-.03v when its on. Also the engine pulls more vacumm at the same rpm with it on, quite a bit more. I like having the engine at 18-19 vacumm instead of 16-17 so i leave mine on. I wish the damn thing was less noisy though.
If yours is the same either way, I'd say theres a problem with the system somewhere. I used a bigger check valve for the vacumm line that feeds vacumm (from the back of the extension manifold) to the two solenoids that connect to the ACV stuff which seemed to have made the system work better, the small one that was originally on there seemed to be quite restrictive.
RE-Mamamia
Sep 11, 2015 02:13 PM
