Amp under 3rd gen seat ?
Old Jan 21, 2002 | 09:17 AM
Want2race's Avatar
Bigger and better things
Anyone put a 4 channel amp under the driver/passanger seat ??
Thanks~
Old Jan 21, 2002 | 10:24 AM
bbeavers's Avatar
Amp under FD seat.
Truthfully I don't think it's possible. If you look under there you will see that the seat bottom springs are exposed so that when you sit in the seat those springs come close to touching the carpet. I would mount the amp under the rear storage compartments, plenty of room, and also puts the added weight in the lowest most central area of the car. That whole plastic piece back there comes out, this is also the recommended spot for most of the battery miniturization kits.
Old Jan 21, 2002 | 10:41 AM
Anderson's Avatar
NOT in a 7
There is not enough cooling (or maybe even mounting) space under RX-7 seat, if you do manage to d it, your amp will over heat too quick due to the lack of space.
Old Jan 21, 2002 | 01:08 PM
Flybye's Avatar
It's never fast enough...
There ARE amps with built in fans, so if you find yourself one of those, cooling may not be too much of an issue, but space will...
Old Jan 21, 2002 | 01:49 PM
DamonB's Avatar
I say it ain't possible. I can't even fit my hand under the seat. Here's where mine ended up:
befarrer
Old School and Other Rotary
Oct 5, 2015 03:30 AM
