60' times with stock FD suspension???
Old Oct 4, 2005 | 03:49 AM
rg42284's Avatar
Question 60' times with stock FD suspension???
What is considered a decent 60' time on our stock FD suspension? Basically no mods to the suspension whatsoever other than tires.
Has anyone achieved <1.5 on the stock suspension?
Reason I ask is that I will going LS1 in the next few months and just need an idea on what kind of 60' I should strive for.
Old Oct 4, 2005 | 01:16 PM
73828793's Avatar
went RX crazy............
best i have ever done is 1.7 ,but my suspension is shot.
Old Oct 4, 2005 | 01:32 PM
Rxmfn7's Avatar
Do a barrel roll!
Id suggest upgrading the LSD unit ( KAAZ or Cusco ) , a diff brace, and looking into some upgraded rear axles if you plan on doing alot of drag launches. The stock FD rear is very strong, but with that power and torque, hooking up at the strip will most likely break something quickly. As long as everything else is in order, with a good launch on some decent drag radials, I have seen 1.6 60's out of an FD.
Old Oct 5, 2005 | 05:26 PM
OneBadFox's Avatar
I've pulled a few 1.60 60 ft in my ls1 rx7 on a 255/5016 drag radial, until the stock torsen rearend took a ****.
Old Oct 5, 2005 | 05:38 PM
rg42284's Avatar
How were you launching fox? I would think a 5000 dump will get it done.
I don't live too far from kaaz usa so i will be getting mine there as i wouldn't want to worry about a broken rear.
My plans on my LS1 will be to run 9's with a trex cam, jtr longtubes, n1 duals, asp pulley, ported tb and a 150 shot.
Did you spray on your time on your sig, fox?
Old Oct 6, 2005 | 07:31 AM
LUPE's Avatar
jigzawrx7 pulled a few 1.35's on stock suspension....
Old Oct 10, 2005 | 09:23 PM
FastEddie's Avatar
crunch
Wanna pick me up a kaaz when your getting yours?
My stock torsen diff. First launch w/ first time at the strip. Netted me a 3.69 second 60ft time.
Old Oct 10, 2005 | 11:36 PM
rfreeman27's Avatar
at least yours didnt explode, they were pissed as they mopped gear oil off the starting line
ive cut 1.5's
cant wait to hook up the 2 step
Old Mar 1, 2007 | 11:33 AM
2MCHPWR's Avatar
FD / LSX
i got 1.51 on ET streets bias ply 11.5x16 on stock rear suspension:
1.57 on ET street radials with a bog. got axle hop with the DR's if i tried aggressive launch.
