Sponsored by: CARiD
Odd Rotary Question...
Old Sep 27, 2005 | 02:54 AM
iwantarotory's Avatar
Question Odd Rotary Question...
I'm not all that familuar with the rotary engine so You guys might find this a stupid question but it has some relavance to me so... I would like to know if the rotor housings can be reversed. Meaning have the intake/exhaust on the plug side and the plugs on the intake/exhaust side. Or can we reverse the excintric shaft and swap the 2 ends of the engine around?
Thanks
Fukae
Old Sep 27, 2005 | 02:59 AM
Ottoman's Avatar
always modding
if u swap the engine aroundm then it would turn backwards... u would have 5 gears in reverse :p
ingoring the front and back of the engine and assumin u could theoretically turn it around..
not sure about ur first Q.. if u mean can u Flip a housing around.. then how do u plan on getting air without an intake manifold into the engine? and exhaust out...
again ignoring all the water and oil passages and everyhing else inside :P
Old Sep 27, 2005 | 03:07 AM
thats what I'm asking. can it be done would the water and oil still flow properly if done? would the engine run? ofcourse I understand that i would have to make or atlest mod the intake/exhaust manifolds
Old Sep 27, 2005 | 03:13 AM
RETed's Avatar
WHY?
Are you trying to swap this into a FWD Honda???
-Ted
Old Sep 27, 2005 | 03:32 AM
Originally Posted by RETed
WHY?
-Ted
**** NO! (I HATE hondas... well most of em) Just considering posibilities for my application <smile>
Old Sep 27, 2005 | 12:17 PM
Maybe that was abit harsh sorry bout that but no no plans to put it anywhere near a honda. So far the car that I'm gonna use seems to be the frist gen mr2 (sry relized this morn that I failed to metion what my application was <smile>). So either way thanks again for the help
Fukae
Old Oct 1, 2005 | 11:31 AM
H4Inf's Avatar
Fukae
sounds like a mad idea damn mr2's are underpowered hehe, and a little lighter than rx7's
You might want to go over detailed plans of the rotary as im sure it probably wouldnt last as long spinning in the other direction.. surely theres a way you could mount it to work as is though
all the best with it !
Old Oct 1, 2005 | 11:56 AM
yeah I'm hoping actualy I think i have found a few ways to do just that
Fukae
Old Oct 1, 2005 | 11:59 AM
H4Inf's Avatar
yea i remember seeing in the manual and hearing many ppl say not to spin the rotor in the other direction, i never heard why tho, maybe its a myth... maybe not
Old Oct 1, 2005 | 10:51 PM
savana's Avatar
savanna
for a start the oil seal springs are designed to push the oil seal out with more force when turning in the correct rotation, due to them lagging in their groove if you spun the engine backwards the springs wouldnt be providing enough tension to expand the oil seals against the plates. by simply swapping the springs so the blue paint was on the front faces of the rotor would correct this though.
Old Oct 1, 2005 | 11:30 PM
rxtasy3's Avatar
Thanks
Fukae
i can answer ur question with a question. can u put a cylinder head on backwards and the engine still run? no, they wont bolt together.
Old Oct 2, 2005 | 05:57 AM
however if you did fab the head to mount backwards and fabed the block to support the crank being put in backwards then yes the engine would run. i dont expect to use factory parts now that i have had a few replys and talked to a few peeps that are knowlagable about the 13b even when i first asked i doubted that the coolant ways and oil ways would match up. I thought I might as well ask. the biggest question i have is if i did fab some rotar housings where all the holes were on the oppisite side would the engine run (please forgive my lack of knowlage earlier after learning a bit i scraped the idea of putting the engine together backwards)
Thanks again
Fukae
Old Oct 2, 2005 | 05:58 AM
H4Inf's Avatar
Thanks again
Fukae
you should pickup a blown motor from somewhere for a few bucks if not free, and pull it apart and see what you can see have a play
thanks for the info this might come in handy at some point ill let you guys know what all happens
Thanks
Fukae
Old Oct 2, 2005 | 06:00 AM
actualy im doing that in about 2 weeks i found a place that will give me a complete 13b (not sure if its good or not) for 100 bucks
datfast1
Old School and Other Rotary
18
Jun 20, 2019 10:53 PM
Under PSI
19
Sep 23, 2015 11:47 PM
datfast1
West RX-7 Forum
Sep 14, 2015 06:58 PM
andyvideopro
SE RX-7 Forum
Sep 5, 2015 06:56 PM
Murilli
Midwest RX-7 Forum
Sep 3, 2015 09:10 AM
