Haltech Problem w/ aftermarket tach on E6X
Old Sep 26, 2005 | 03:55 PM
rotorizit's Avatar
Got Boost?
I have problem with my Auto Meter tachometer. It works fine and reads very accurately compared to the engine data page until 6000 rpm. At 6000 rpm the rpm readings on the tach drop to zero but the haltech software is still reading rpms and the car is still running. And pulling hard! I just dont understand why the rpms are dropping off. I have the tach set up for 2 pulse per revolution, and the signal wire is connected to the trigger signal wire on the leading coil. Any ideas?
Old Sep 28, 2005 | 05:58 PM
rotorizit's Avatar
Got Boost?
anyone?
Old Sep 28, 2005 | 10:43 PM
Claudio RX-7's Avatar
EFI Tech Wannabe
What is your gain set at in the software, on the trigger setup?
Old Sep 30, 2005 | 09:17 PM
rotorizit's Avatar
Got Boost?
I forget, Ill have to check.
Old Oct 7, 2005 | 12:45 PM
rotorizit's Avatar
Got Boost?
my trigger gain is 2
Old Oct 7, 2005 | 08:34 PM
EFI Tech Wannabe
Hey, lower the gain to zero, ( 0 ), the haltech E6X has a very sensitive trigger circuit, so a gain of zero is sometimes best.
Old Oct 11, 2005 | 05:54 PM
rotorizit's Avatar
Got Boost?
thanks Cladio, I'll try it and post back.
Old Oct 26, 2005 | 04:57 PM
rotorizit's Avatar
Got Boost?
Ok, I tried changing my gain. With no evail. The rpms still drop to 0 after i hit 6000 rpm no matter where the gain is set.
rgordon1979
40
Mar 15, 2022 12:04 PM
ZacMan
Sep 19, 2015 09:20 PM
vmerino
Sep 5, 2015 11:26 AM
