Boost problem
Old Jan 19, 2002 | 05:34 PM
penko's Avatar
Boost problem
I have a blitz boost controler,the problem is that i have it set at 12psi but when my car hits around 6k my boost drops to 7 or even 6psi.
Can somebody help me with this,i have free flow exhaust,and 2xtra injectors,thanks
Old Jan 19, 2002 | 06:52 PM
Scott 89t2's Avatar
SOLD THE RX-7!
the stock turbo is too small to run high boost at upper RPM's. if you add a good intake and 3" TID it will help
Old Jan 19, 2002 | 07:23 PM
penko's Avatar
Thanks for the reply,i have an arospeed filter,just one question,whats TID,so what should i do with the intake
Old Jan 19, 2002 | 07:43 PM
Scott 89t2's Avatar
SOLD THE RX-7!
is it a cone filter or a drop in to the stock box? the TID (tubo inlet duct) is the pipe from the air flow meter to the turbo. it has some nasty bends in it. if you do a search on the fourm for TID you'll find some instrutions on making them. I think you need to remove the air pump to make one fit though. you hav to be carfull though, you might creep up another psi or 2 after wards.
Old Jan 19, 2002 | 07:52 PM
penko's Avatar
Yea its a cone filter and i'm using the stock duct with it
rgordon1979
40
Mar 15, 2022 12:04 PM
sherff
Sep 12, 2015 12:22 PM
AXA
Sep 5, 2015 10:06 AM
gabescanlon
Sep 5, 2015 12:09 AM
tiger18
Sep 3, 2015 08:27 PM
