Are wheel spacers bad to use?
Old Sep 24, 2005 | 01:14 AM
prew's Avatar
Hey guys I have gotten mixed answers to this question. I figured I would ask the professionals over here. I would like to run my stock FD wheels on my S14. I tried to put them on but the wheels hit the coilovers. I think a 25mm spacer would do the trick and I see plenty of them for sale on ebay. My question is are wheels spacers crappy? Unsafe? Thanks for any responses.
Steve
Old Sep 24, 2005 | 07:22 AM
respecttheseven's Avatar
PREW: the key is getting the right rigid new lugs and making sure u press them right into ur drum. never short yourself of lug length.
Old Sep 24, 2005 | 09:13 AM
aznpoopy's Avatar
strike up the paean
crappy, yes.
spacers are like a bandaid for bad sizing on wheels...
s14 tends towards low offset wide *** wheels. it can do 9+15 in front, no problem. even wider in the rear. spacers + extended lugs aren't cheap enough to justify using them, imo.
save up a bit more and go for some used aftermarket wheels.
Old Sep 24, 2005 | 10:59 AM
Rx7@Rocketship.com's Avatar
Steve
A large offset spacer will "overload" the suspension and bearing. How drastically are these components effected with a 1/2" spacer? Hard to say.
I know someone that ran spacers at the rear of his FD for years without any problems.
Another interesting point worth pointing out... Porsche offers rear wheel spacers as a factory option for their 997 models. Go figure.
With that being said, I would be more concerned with the vibration caused froman ill-fitting spacer than overloading the wheel bearing with a SMALL spacer.
David
Old Sep 24, 2005 | 06:13 PM
prew's Avatar
thanks for the responses guys. i always thought of spacers as the cheap way out but was never sure. i guess i will find other wheels to use.
Th0m4s
Feb 26, 2019 02:04 AM
