what timing and split to aim for at around 30 psi
Old Sep 22, 2005 | 09:44 PM
fastcarfreak's Avatar
3rd motors a charm I hope
Alright guys, I was just wondering what timing and split I should aim for if i plan to run around 30 psi or higher on race fuel and my t78? Right now I am running around 25 psi and I am running 15 degrees with 12 degrees split. I was told by steve kan that this timing is good til around 25 psi. He tuned my car up to about 18 psi on the street and set me a starting map to tune on up. From about 18 psi, I have been turning the boost up a little at a time and tuning with my wideband for around 10.8-11.0 AFR.
Thanks for any and all imput!
Adam
Old Sep 22, 2005 | 10:02 PM
tearbo2's Avatar
Adam
15 deg w/ a 10 split @30 psi
Old Sep 22, 2005 | 10:12 PM
nice, even less split than me. What turbo, and what did you dyno at? What injectors are you running.
Adam
Old Sep 23, 2005 | 07:34 AM
tearbo2's Avatar
Adam
the turbo is a pt 74 , dyno jet @ ptp motorsports (austin tx ) , and i run 4 1600cc
w/ the ptp dual pump setup. the s/5 stock ports netted @ 550 rwhp due to the small ports, but she flew down the track w/ the best of them. good luck w/ your setup!
Th0m4s
Feb 26, 2019 02:04 AM
C. Ludwig
Jan 30, 2019 06:31 AM
Microtech
30
Apr 23, 2016 06:37 PM
Microtech
Aug 23, 2015 11:04 AM
