Power FC GM 3 Bar Map Sensor and Large Port? Settings going to change?
Old Sep 22, 2005 | 11:57 AM
dhahlen's Avatar
FD Under Construction =P
I can't get my car to idle properly, I've found tons of different settings on the forum for the 3 bar map sensor and I am not sure which to use. I am using a power FC and so far I've come up with the following:
43860 offset 0
41800 offset 0
43500 offset 320
44000 offset 357
I remember there being one that was like 72800 or something. Anyway, my engine has a large port. Any help would be great, thanks.
Old Sep 22, 2005 | 03:37 PM
Howard Coleman's Avatar
Racing Rotary Since 1983
pm'd you
Old Sep 22, 2005 | 09:19 PM
cewrx7r1's Avatar
Eye In The Sky
Might not be the map sensor settings but: O2 control, idle control, ISC,, timing, fuel, etc.
Old Sep 22, 2005 | 10:01 PM
dhahlen's Avatar
it was PIM voltage for the 1000rpm range, i changed it to 75% and it works. Forgot to do that... car was dumping too much fuel @ idle.
sen2two
AEM EMS
Oct 23, 2015 07:51 PM
befarrer
Microtech
Aug 22, 2015 05:52 PM
Snook
Aug 15, 2015 08:18 AM
