Lowering the 7
Lowering the 7
I'm hoping someone has dropped their car a full inch in front and back and I wanna know what your setup is.
I'm curious if you have any rubbing problems or anything of the like.
I would like to run 17x7's with an offset of +43mm all around and drop the car an inch.
Do you think I would have a problem with rubbing?
What size of tires should I use?
Ok I just did this... I have a 17x7 40mm offset with 225/50's all the way around... Lowered the car over an inch all the way around, and the outside of the fender is fine as long as you roll it a little... The inside edge of the tire is touching the spring though, so I need smaller tires... Ordered some 205/40's for the front and that should do the trick... The back has plenty of room... Wouldn't run anything wider than a 225 out back though...
iamsisyphus
Sep 27, 2015 01:42 PM
