Coolants sensor and water pump...
Old Jan 18, 2002 | 04:03 PM
flying taco's Avatar
Rock Star.... almost
Hey guys... where is the sensor that tells that damned annoying buzzer that you don't have enough coolant?? I KNOW I have plenty of coolant cause after the thing went off I opened up the cap last night and it was up to the top. Also, how can I test to see if my water pump is working?
Thanks
Aaron
Old Jan 18, 2002 | 04:08 PM
cymfc3s's Avatar
I Raise Chickens
its the one on top of the radiator. The blades on the water pump are metal, so they dont really go "bad" they start to seep and then you replace.
Old Jan 18, 2002 | 05:44 PM
HAILERS's Avatar
HAILERS
On a 87 you can have water at the filler neck and at the same time have nothing but air in the top of the radiator, where the sensor resides that turns the buzzard on and off. On your car, you have to eliminate that air pocket. Mazda put a bleed screw on the right hand side of the radiator. You need to remove it when filling at the filler neck. When water comes out of the scres hole you put the screw in and at the same time keep filling to the top. That sensor with the one bullet connector, has to be covered with engine water so it can put a ground on the buzzzard circuit, to turn the thing off. Right now your radiator is not full.
Old Jan 18, 2002 | 07:41 PM
Cool... thanks... i'll try it tomorrow when its light out.
Aaron
msilvia
15
Sep 11, 2015 12:13 PM
mulcryant
Sep 9, 2015 05:24 PM
ZaqAtaq
Sep 5, 2015 08:57 PM
