Engine Management Forum Use this area for discussing Haltech, Wolf 3D, Power FC, AEM and any other aftermarket ECU upgrades. Help/Questions/Tuning
Turbo Timer Install?
Old Jan 17, 2002 | 10:04 PM
Sweet7's Avatar
Anti-EMO!
Hey guys i just bought the new Apex Turbo Timer. I am installing it and ran into some trouble
Old Jan 17, 2002 | 10:05 PM
Sweet7's Avatar
Anti-EMO!
Grr hit "submit" prematurely. SO anyways there is this point where it says to "pull harness coming from key cylinder." how does one do that?
Old Jan 21, 2002 | 12:53 AM
MastaCow's Avatar
it's a PITA since the space there is kinda tight.
Remove the steering column surround (three screws if I remember correctly), then pull the lower plastic (the one with the vent. There's three screws to that one too.
If you look at your key cylinder from below, at the end of it (to the left) is a white harness, with a red cliplike thing locking it together. I muscled mine apart, but I was in a low light situation and was doing the install because I was blocked in and bored.
THe wiring harness will be a tight fit. Just be patient, crawl in and be careful not to pull any other wires loose from the other connections in the area.
Th0m4s
Feb 26, 2019 02:04 AM
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
