Battery "Cut-off" switch location pics
Old Sep 13, 2005 | 07:06 AM
88fc3sw/HX83's Avatar
Guys,
I just wanted some visual pictures for ideas on where to mount the NHRA certified battery cut-off switch. Pictures of it mounted in a 2nd gen would be nice
Thanks,
Jim
Old Sep 13, 2005 | 09:03 AM
AnthonyNYC's Avatar
Stay tuned...
Originally Posted by 88fc3sw/HX83
Guys,
Thanks,
Jim
Look in the back under the tailights, this might work well for a 2nd gen as well.
Anthony
Old Sep 13, 2005 | 09:42 AM
LUPE's Avatar
I don't have any pictures but my battery cut-off switch is mounted right in the middle of my license plate, between the letters. I couldn't see myself cutting a hole in my bumper or tailight.
Old Sep 13, 2005 | 10:20 AM
Another place is the rain tray orifice under the windshield wipers.
Old Sep 13, 2005 | 10:52 AM
MarkPerez's Avatar
Tennis, anyone
The NHRA says it has to be on the rear of the car (to race) and in plain sight. there is a differance between a full blown race car, bracket/street car. the picture of the yellow 3rd gen above i would say did a tastefull job of placing the switch,well done.
a 2ed gen rx7 is a challange, while keeping it street legal. i would install the switch into one side or the other of the back-up lights. cut the lens remove the bulb/socket and fab. out of aluminum a 'plate' that replaces or covers where the back-up lens used to be and mount the switch to the plate. you still have 1 back-up light.
maybe
good luck
Old Sep 13, 2005 | 11:16 AM
Thanks for the info guys! Well, on my 2nd gen, we shaved the 3rd brake light. Do you guys think it would look funky in that space?
Attached Thumbnails Battery "Cut-off" switch location pics-picture-023resize.jpg
Old Sep 13, 2005 | 11:26 AM
LUPE's Avatar
I'd put it right where that stupid tree is in the middle of your license plate. That's where mine is.
Old Sep 13, 2005 | 11:47 AM
turbo80cid's Avatar
build a box behind the license plate. then just remove license plate at the track
Old Sep 13, 2005 | 11:54 AM
I agree, you should do that, you coming to the track day on the 30th still?
Old Sep 13, 2005 | 12:40 PM
turbo80cid's Avatar
like this
Old Sep 13, 2005 | 02:32 PM
The Spyder's Avatar
Never give up!
Im putting mine right in the center of the licence plate .
Old Sep 13, 2005 | 02:45 PM
turbo80cid's Avatar
I would bet that will get you a ticket or at least pulled over.
It would be like me putting a piece of tape on the plate to change a number or letter.......tampering?
Old Sep 13, 2005 | 02:48 PM
The Spyder's Avatar
Never give up!
Normal licence plate is covered by the dealer plate while city driving...
Old Sep 13, 2005 | 03:23 PM
turbo80cid's Avatar
I guess I'm dumb because I don't understand what you are saying.
how can you put one plate over another plate if you have a switch sticking out of it?
Old Sep 13, 2005 | 03:39 PM
The Spyder's Avatar
Never give up!
The car I am building is for a friend who ownes a dealership, and has one of those plate with rubber mounts that just hangs over the other plate. (basicly its a rubber casing for the plate, with two arms that go up and are shut in the hatch to hold it in place.) It dosent directly mount over the normal plate.
Old Sep 13, 2005 | 03:46 PM
turbo80cid's Avatar
oooohh!! I got it now.
Old Sep 13, 2005 | 05:54 PM
I thought about putting it there, we'll see! As for the "track day", I don't think i'll be making it out this year:
1) I don't have spare wheels/tires to run
2) I don't have extra fuel to bring to the track
I REALLY wanted to go though, it'd be fun to hang with some rotor heads!
Old Sep 13, 2005 | 07:39 PM
MarkPerez's Avatar
Tennis, anyone
Thats a dealer plate for test drives. The white FC above may have something there.
cool idea !!
Old Sep 14, 2005 | 02:07 AM
Originally Posted by turbo80cid
like this
I think your idea might work really well!
Thanks,
Jim
Old Sep 22, 2005 | 11:36 PM
Kill No Cone's Avatar
Pegasus Racing has an email special going on cut-off swithes that are of a high quality.
One is for a car w/o an alternator and the other is for a car with an alternator. The second one has contact points for four leads and a resitor.
Can someone explain the extra wiring for a car with an alternator?
Can't I just run the basic one as a on/off for the positive terninal?
What am I missing?
JEB
Old Sep 23, 2005 | 07:57 AM
Travis R's Avatar
trying to build a racecar
Hmm, this is just a guess since I've never hooked up a kill switch.
If you just disconnect the battery from the system, then it won't start. But if it's already running then the alternator will continue to supply power... so you need to disconnect both to actually kill the car.
Old Sep 23, 2005 | 08:24 AM
DamonB's Avatar
Yep. Cars with alternators are supposed to run a two pole cutoff switch. One disconnects the main at the battery and the other disconnects the alternator output.
Old Sep 23, 2005 | 11:26 AM
LUPE's Avatar
You can see that I mounted mine in the middle of my license plate.
Old Sep 24, 2005 | 02:53 PM
Of course, the alt will keep the engine running ~ Thanks
Old Sep 24, 2005 | 03:09 PM
RoadRaceJosh's Avatar
Hobby or mental illness?
Not if the alternator output goes to the battery side of the cutoff switch!
