I need to Borrow Microscopic Camara.
Old Sep 13, 2005 | 04:35 AM
FC/DC's Avatar
I need a Small video cam so i can look into the inside of my engine to check apex seals. I cant see anything unless i take the exhaust apart, and even then i cant check out the apex seal Ends. So basicly if someone had a pin hole cam i can put into the engine to check this it would be grreat!
Old Sep 13, 2005 | 02:32 PM
partly mazda's Avatar
old parts
get a mirror and flashlight and look insise the leading plug hole. It will at least tell you if the seal is still in there. you also can check the spring pressure with the eraser end of a pencil.
john
Old Sep 13, 2005 | 09:52 PM
rmriggin's Avatar
no clever remarks...
oh the possible comments I could make... thanks for doing the right thing partly mazda and helping out.
Old Sep 13, 2005 | 10:54 PM
FC/DC's Avatar
heh Im gona try everything. just cant do much here in kirkland, they are tight on rules about working on the car.. they already complained about the smoke that wont burn off in my exhuast, I put way to much in there, its SIZZLIN and POPPING its very bad. might take months to burn off.
Old Sep 14, 2005 | 04:09 PM
Richard Miller's Avatar
Damn, it did start!
I can see people complaining about the a-bomb dropping rotary. But there is a city ordance that says you cant spin your own wrenches?
Old Sep 14, 2005 | 10:45 PM
1noblerider's Avatar
I know what you want. those cameras are expensive. I talked to an olympas repersenitive to see if I could pick up a deal on a used one for a buddy of mine that races sprint cars. $10000 for a used one. Good luck getting to use one. boy it would save alot of time. Perhaps instead of a flexable scope you may find some one that has a straight one that has a really wide angle. You will also have to put some light in there with a fiber optic light source I beleive. Ive only heard of profetional race theams that use that kind of stuff. It is for the most part portable.
Old Sep 15, 2005 | 12:47 AM
FC/DC's Avatar
wow yes that is expensive, i hate to tear it apart and find the apex seal was just stuck, I tryed for two days too unstick it, warmed it up twice, and reved it up. Not sure if i need to drive it to unstick it, or if i can sit still and rev it. but so far if it is a stuck apex seal it is not poppin out yet, I did take it on a short drive the other day though, and i gotta tell ya. I forgot what i am missing. makes me want to work harder to get it running. i have had such bad luck with apex seals im affraid of them now, i mean if it happends agian i think im gona drive off a cliff.
Old Sep 15, 2005 | 08:55 AM
spokanerxdude's Avatar
Less Cubes, More Balls
What your looking for is called a bore scope if you know any aircraft mechanics you might be able to barrow theres, there not 10g's but they are in the 100's so borrowing one from them still might be a challange.
Old Sep 15, 2005 | 02:35 PM
The Spyder's Avatar
Never give up!
Can you drive it? Have you been able to even get it upto operating temp?
Hell, if its dead, might as well drive it until it stops smoking and see if some sprited driving helps .
Old Sep 15, 2005 | 08:23 PM
Busted-7's Avatar
Registered Rx-offender
How long did you let the MMO soak in the rotors before you tried starting it the first time?
Old Sep 15, 2005 | 09:30 PM
FC/DC's Avatar
I let it sit for two or three days. i was really busy and i was not in a hurry so before i left for the weekend i put some mmo in there.. when i got back i turned the engine by hand so it could soke the other apex seal's, I did get it up to operating temp a few times. even drove it around but after it warms up the smoke comes back because of all of the oil in the exhuast, I mean the oil is dripping out of the tail pipes i put so much in.. my mistake but when itsw cold it wont smoke at all. just when the pipes get hot smokes alot, Not as much as when i first started it so im sure its burning off, but i need to get it out on the road a few more times. it seams to me that everytime i start it up it runs smooth for a short time then after few minutes it starts missing agian, not sure if the apex seals are Trying to pop out or not, But if the apex seals are not touching the housing im not sure when is going to pop them out. exept a screw driver (jk) or somthing that wont hurt the engine. other than that it runs cool, no water leaks, coolent seals seem fine, ill know alittle more after i start it up agian and go for a drive.
Old Sep 15, 2005 | 09:33 PM
KompressorLOgic's Avatar
I
just drive around on 1 rotor! lol
Old Sep 15, 2005 | 10:56 PM
old parts
When are you going to look at the seals through the plug holes? too much talk , not enough action
john
Old Sep 16, 2005 | 12:03 PM
I
and why cant you pull off the exhaust manifold to take a look? it isnt that hard... ive done if multiple times on my NA
Skeese
65
Mar 28, 2017 03:30 PM
meximan
Sep 25, 2015 01:39 AM
IgoSlow
Jun 19, 2002 08:43 PM
