Sponsored by: CARiD
compression tested my 94 w/ piston tester...have ?'s please HELP.
Old Sep 11, 2005 | 04:45 PM
TwinTurbo_SE7EN's Avatar
resU deretsigeR
I just did a compression test with a piston tester. I held the check valve open like youre supposed to. I saw even pulses of 90-95 psi on all 6 faces. however both times when I let go of the check valve I saw 125 psi. how is it possible to see 125 psi if all 3 faces are putting out 90-95? is it that the bounces are just too fast to register fully on a piston tester and thats why I only see 90 - 95?
Thanks.
Old Sep 11, 2005 | 05:10 PM
t-von's Avatar
Rotor Head Extreme
Thats called the accumulative pressure. 125 psi is good according to the Bruce Turrentine 13b rebuild video. Your all good.
Old Sep 11, 2005 | 05:55 PM
resU deretsigeR
so then it must be something else? Im thinking it is a short somewhere or a bad CAS, TPS, or MAP sensor. my voltages are good for the TPS and my map sensor shows -39mmHG when off, but it has always done that. I dont know how to check the CAS. Could it be spark plugs? they only have ~300 miles on them. I changed them before I went to the tail of the dragon this weekend.
Old Sep 12, 2005 | 07:34 PM
t-von's Avatar
Rotor Head Extreme
What kind of problems are you having with your car? You first asked a question about compression testing, now your throwing in questions about the TPS and CAS.
ZacMan
Sep 19, 2015 09:20 PM
BLK 93
11
Sep 9, 2015 10:56 AM
SCinfidel
Sep 8, 2015 05:36 PM
ZaqAtaq
Sep 5, 2015 08:57 PM
