car not giving power to fuel pump.
Old Sep 11, 2005 | 01:13 AM
rotaryracer1's Avatar
hello all, a couple months ago i rewired my fuel pump and followed the instructions on www.1300cc.com and it was runnig flawlessly now my 88 t2 is having electrical gremmlins , the main power wire from the wiring harness to the fuel pump is not getting any voltage. i have checked all fuses and looked over the wiring for pinches in the harness or wires and i have found nothing, i have been thinking about just bypassing that wire and hooking up an alternate switched 12 volt source to the fuel pump. i need some advice please help.
Old Sep 11, 2005 | 01:22 AM
NZConvertible's Avatar
I'm a boost creep...
Originally Posted by rotaryracer1
...the main power wire from the wiring harness to the fuel pump is not getting any voltage.
Have you got the fuel pump check connector jumpered when you're checking this? It won't have any power if you don't.
How did you first notice this problem? Problems driving? Does it run?
Old Sep 11, 2005 | 01:46 PM
fc3s1tog's Avatar
just curious but how do you "jumper" the connection? add a ground a 12 volt source?
Old Sep 12, 2005 | 02:10 AM
No, you connect the two terminals of the plug with a bit of wire. A good way is to crimp a male spade terminal on each end of a short bit of wire. They'll plug right in.
Old Sep 13, 2005 | 04:40 PM
one day the car was running the next it was not. so should hook an alternate power source up or what?
Old Sep 18, 2005 | 12:48 PM
ttt
alphawolff
Nov 17, 2015 05:57 PM
cam_7779
Aug 18, 2015 07:48 AM
