West RX-7 Forum Serving California, Nevada, Arizona, Hawaii
Anybody in socal have a 90-91 CA. CRX Si?
Old Sep 8, 2005 | 11:47 PM
GoRacer's Avatar
Speed Mach Go Go Go
Question Anybody in socal have a 90-91 CA. CRX Si?
I had to replace my ECU and could only get a federal one on ebay which does not control the EGR and my NOx is considered gross poluter by about 4x the max. I don't know of any way to lower it. I will try a new O2 sensor, smog pass fuel cleaner stuff, octane boost, race ruel, cold iridium plugs and maybe a cold air intake. If that doesn't do it then I eitther have to borrow a PM6-L09 ecu or pay a tip which is $400 less then a ECU at wholesale tech cost.
Old Sep 9, 2005 | 12:22 AM
DJDINO's Avatar
CEO of Belligerents INC.
Ah Rob, you need to post pics of some almost bare naked gals along with your thread
Old Sep 9, 2005 | 12:30 AM
GoRacer's Avatar
Speed Mach Go Go Go
Old Sep 9, 2005 | 02:26 AM
DJDINO's Avatar
Love the redhead!
Old Sep 9, 2005 | 06:28 PM
GoRacer's Avatar
Speed Mach Go Go Go
I got lucky. Went to a new junk yard and they just received a 91 CRX Si. They let me ****** the ECU before they were supposed to release it.
Old Sep 10, 2005 | 03:20 AM
scotty305's Avatar
~17 MPG
To pass smog, I think hotter plugs is the key, not colder. Hotter combustion temps should keep the cat converter warm, which will help it work better.
Also, be sure you heat up the cat converter right before you have the car tested. Keep the RPM's high for a few blocks before the smog shop.
-s-
Old Sep 10, 2005 | 07:05 PM
SERIES7's Avatar
Embassador to SOY
To pass smog, the key is to post more pics of the redhead.
w3rd 2 yore muthir!
Old Sep 10, 2005 | 07:30 PM
Marcus_F's Avatar
-s-
Hotter plugs don't increase combustion chamber temps. Hotter spark plugs transfer thermal energy from the combustion chamber to the plug threads at a slower rate than cooler plugs. That and the original poster said he was failing due to NOx, which is caused by excessive combustion chamber temps. He needs to lower combustion chamber temps, not raise them. The sole purpose of an EGR valve is to lower combustion chamber temps, which reduces NOx.
If the red head was driving the car, chances are the smog tech would be distracted, and the car would pass.
Old Sep 10, 2005 | 08:00 PM
DJDINO's Avatar
Mr. Rob,
Where are more pics of the red head....
Old Sep 11, 2005 | 12:40 PM
GoRacer's Avatar
Speed Mach Go Go Go
mduchek
Sep 20, 2015 07:03 AM
