noob...got questions
Old Sep 8, 2005 | 11:06 PM
russmazda's Avatar
Hey guys i just joined this forum, reason for doing so is that i am about to buy a 1986 rx7 from a buddy of mine for about 1500 and i just had some questions...none that he hasn't answered, but i just need a second opinion for security.
1) do rotor engines last really a long time..like much longer than 4cyl.? is 130000 too much
2) how do you like ur fc?
3) is it worth the money? fun to drive?
4) are there problems w/ the ignition, another friend of mine said that the rotory engines have a prolem w/ fludding(rx8)...
can yall please list some of the major probles i can expect or that you have encountered.
thanks a bunch
-Alex
Old Sep 8, 2005 | 11:17 PM
Fcdrift05's Avatar
The Power of Rotary
1) 130,000 without a rebuild is probally bad
2)I love my TII
3)very fun to drive, well worth the money
4)if you look through the forum you will see some people do,I personally have a fuel cut switch in case and it works fine ususally dont need the fuel cut
Kevin
Old Sep 8, 2005 | 11:19 PM
Fcdrift05's Avatar
The Power of Rotary
also you should look at the 2ns Gen FAQ it has some helpfull stuff in there
kevin
Old Sep 8, 2005 | 11:21 PM
Kai's Avatar
Kai
Rotorphile.
1) My first FC lasted to 146k miles before I sold it, still running fine. My current one is at 171k, running strong. Both on original, non-rebuilt engines.
2) I love it. I've driven a pile of different cars and my FC is still my favorite. (My daily driver Stealth doesn't even begin to compair, even though it has a load more torque)
3) YES.
4) No, unless the engine was abused or is about to die. I've never been unable to start my engine due to flooding.
Old Sep 8, 2005 | 11:23 PM
russmazda's Avatar
yeah man, but the previous owner bought a lot alot of new parts for the car, so it should be alright for the time being, but if i get it i'm probably gonna get a new engine for it and tranny for 1500 and just built it up and swap it in(hopefully)
-Alex
Old Sep 8, 2005 | 11:25 PM
russmazda's Avatar
awesome that helps me a good bit, i'm pretty damn sure me gonna get it now
Old Sep 8, 2005 | 11:30 PM
0x0000FF's Avatar
do it!!!! The FC is hella fun to drive; don't know about n/a but it's one of the most intense turbo cars i've had the pleasure of driving. insane fun.
Old Sep 8, 2005 | 11:49 PM
Kai's Avatar
Kai
Rotorphile.
A lightweight N/A (Base, Base/Luxury, Base/Sport) will keep up with a TII no problem. The TII is a porker compaired.
Old Sep 8, 2005 | 11:58 PM
russmazda's Avatar
while i got the questions going, what is the compression of a new rx7 engine (back in the day) cuz the one i'm considering buying has about 160, and i was told that the new engine has 160-162
Old Sep 9, 2005 | 12:02 AM
1987RX7guy's Avatar
Eat Rice Don't Drive it.
IIRC 120psi warm compression is just about perfect. I don't know how you got 160.
Old Sep 9, 2005 | 12:40 AM
Kai's Avatar
Kai
Rotorphile.
I thought 125 was about absolute perfect, but I guess it depends. I haven't heard of anyone mentioning over 125.
Old Sep 9, 2005 | 01:33 PM
russmazda's Avatar
hmm..that would suck if it was a scam...where do yall know this from...is it written in the manual for the car...or can i find this out somewhere online??
Old Sep 9, 2005 | 02:07 PM
iceblue's Avatar
Passing life by
1) do rotor engines last really a long time..like much longer than 4cyl.? is 130000 too much.
This is to vague b/c this depends all on the last owner how it was driven and most importantly how it was upkeep. I will list my experience with all my rotary’s.
151k blew side seal
141k blown coolant seal
165k blown coolant seal "turbo"
110k blew coolant seal friend over heated it.
210k still going strong 90psi on all rotors
44k runing stong and I rag it!
I love these cars they are a true passion in my heart and what keeps me going with them.
I think about this when I am always working on broken parts but in the end the hard work makes it even bettor. This upkeep repairs is all due b/c hey its a 16yr old car after everything is brought up to specs and repaired the car will treat you like new.
4) are there problems w/ the ignition, another friend of mine said that the rotary engines have a problem w/ flooding.
No issues with ignition but flooding can be another story and a FC that is in proper running condition will prolly not ever really flood on you.
(rx8)
No they fixed this in the rx8 I have 44k on mine not once flooded!
can yall please list some of the major problems i can expect or that you have encountered.
This depends on the upkeep. I recommended a full suspension bushing replacement if not done by other owner and front and rear assembly’s tie rod ends and ball joints b/c these can be disasterus failures. I recommend checking and replacing all sensors as needed and any mechanical parts needed like rear end if LSD or u-joints clutch and so on. After that a basic 70k tune up!
Old Sep 9, 2005 | 02:13 PM
J-Rat's Avatar
Alcohol Fueled!
Note: The factory Mazda OEM driveshafts from '83-on have non-replaceable U-joints -- you have to buy a new driveshaft if they wear out.
Old Sep 9, 2005 | 02:16 PM
ddub's Avatar
i am legendary
Technically that's what Mazda says... but if you search for u-joints someone found a place that carries ones that will fit. It is very difficult to replace the u-joints in the stock driveshaft, but it's been done and there's a semi how-to on the way to do it, and there's a part number and company to call to order the u-joints. I believe it was Audiofight or something that made the thread.
Old Sep 9, 2005 | 02:21 PM
J-Rat's Avatar
Alcohol Fueled!
I remember seeing it, but I would rather just get the mazdatrix propeller shaft with the removable u-joints in it. Not to mention that Audiofight may have found u-joints that fit, but were they of the right geometry?
Old Sep 9, 2005 | 02:22 PM
ddub's Avatar
i am legendary
The u-joints he got were under mazda rx7 from what I remember when I called to order mine.
And I agree, mtrix shaft is much better, I tried replacing my u-joints and failed... now I have a new mtrix shaft.
Old Sep 9, 2005 | 02:25 PM
iceblue's Avatar
Passing life by
http://www.arizonadrivelines.com/
Has replaceable joints for our car. Just call them and tell them you have a FC :-D
What you need to do to make your life allot easier is take it to a machine shop and have the old joint pressed out will save you from allot of headaches. Take a file or dremel and grind the burrs down from the old stacked u-joints. Pull the rubber sleeves off the new ujoints caps and slide them onto the new ujoint. Place the new ujoint inside the shaft and slide a cap in through the outside of the yoke onto the ujoint repeat 3 more times. Press these caps back into place to fully seat them onto the new ujoint. Screw in the zirt fitting and greas it up!
edit: I am not going to argue that ordering a mtrix shaft would not yield in a much bettor shaft and build. B/c obviously it WILL so if your down and got a few extra bux I will stamp it.
Old Sep 9, 2005 | 06:27 PM
russmazda's Avatar
awesome thanks alot
Old Sep 11, 2005 | 10:10 PM
0x0000FF's Avatar
I said Fun, not fast
_Tones_
May 25, 2021 05:37 AM
Nosferatu
Sep 5, 2015 02:13 PM
