Brakes Dying
Old Sep 7, 2005 | 08:04 PM
BklynRX7's Avatar
King of the Loop
Arrow Brakes Dying
Ok well for the past few days every tiem i drive after a good 20 minute of normal traffic my brake pedal becomes softer and softer and needs to be pushed further and further down to stop. At some points I almost ahve to touch the firewall to even slow down. My father and the haynes manual believe my master cylinder is going since im not losing/lacking fluid. IS there any other possibility or way to test the cylinder.
I would aslo like to know a bit more about swapping in a more powerful cylinder. You see I have a base model and am planning on swapping in the 4pot setup (its sitting in my garage) eventually. I am told it help to have the brake cyminder from a car with the 4pot setup but am not sure about a few things
If i swap in the 4pot cylinder will it damage or not work with my current 2pot setup?
If I swap the cylinders will I have to swap any of the other brake lines in the car? Specifically the hard lines that run through the car.
Old Sep 8, 2005 | 12:11 AM
BklynRX7's Avatar
King of the Loop
Arrow
BUMP
Sorry for bumping so soon but theyre my BRAKES and id like to get some opinions and fix them asap.
Old Sep 8, 2005 | 01:00 AM
RX7Dragon's Avatar
Recovering Rotaryist
To swap in the 4 pots you gotta get the 4pot MC and brake booster for it to work properly. 4 pot brakes with a one pot setup aint a good idea.
Old Sep 8, 2005 | 01:08 AM
BklynRX7's Avatar
King of the Loop
My question was will I be able to use the 4pot cylinder/booster on my 1 pot setup temporarily. I am still also curious to know whats wrong with my brakes to begin with.
Old Sep 8, 2005 | 06:29 AM
RETed's Avatar
Is the brake master reservior losing fluid?
If not, it's most likely the brake master needs to be rebuilt or changed - the internal seal is dead, and the fluid is just bypassing the seal causing the brake pedal to slowly drop to the floor.
Because the fluid is just "circulating" inside the brake master, the fluid does not leak anywhere.
-Ted
Old Sep 8, 2005 | 07:13 AM
Rotaryhaven's Avatar
Total Rotary Domination!
Agree with reted on this.
Old Sep 8, 2005 | 08:11 AM
aznpoopy's Avatar
strike up the paean
do it right or don't do it at all
4pot MC + 4pot brakes
or
1pot MC + 1pot brakes
i wonder if mixing and matching would **** up your brake bias.
i wouldn't **** around.
barkz
Power FC Forum
37
Nov 21, 2020 09:34 AM
Devon300zx
15
Sep 16, 2015 06:57 AM
The1Sun
Sep 15, 2015 04:45 PM
The1Sun
Sep 7, 2015 10:21 PM
Tem120
Sep 7, 2015 09:53 AM
