a good manual boost cotroller for a good price
Old Sep 7, 2005 | 10:31 AM
darth fc3s's Avatar
peolple out there i am new to the turbo thing so i got a few questions about a manual boost controllers. first off what is a good manual boost controller for a good price . i see a turbo xs in the summit catalog for 70.00$ ,is this a good deal? I will probly run between 10 to 15 psi. also how do you set the boost on a maual controller?and i have dual wastegates so do i need two controllers?please humor me and and let me know something , i'm trying to get my car ready to go to NOPI in the ATL so im scambleing to get my car running. FYI i've got a gt 40 turbo in it now if that helps any.
Old Sep 7, 2005 | 10:51 AM
turbine's Avatar
yes the turbo xs one is a good MBC. although i do not like manual boost controlers as boost is unstable.
ive seen my boose drop off and spike with a MBC
you set the boost on a MBC by tightening or loosening a screw. you can run one controler or two if you realy want too.
Old Sep 7, 2005 | 11:26 AM
BlaCkPlaGUE's Avatar
I live in an igloo
All the boost controller consists of is a valve, thats it. How open/closed the valve is determins how much boost is needed to activate the wastegate diaphram spring.
So, with that being said and looking at the title, you could seriously make your own.
Old Sep 7, 2005 | 11:28 AM
impulsive-rx7's Avatar
I hate this f0rum
www.boostcontroller.com
Old Sep 7, 2005 | 11:32 AM
ultradef's Avatar
Ready to Rock
Boost dropping off and spiking may be a problem with turbo sizing/function and/or your wastegate.
I have a TurboXS MBC and it works great. Boost stays rock solid. I bought mine from Summit. Boost is set by turning an allen key...not exactly precise, but its fairly easy to find the correct position for your desired boost. But then again, if you're dropping all that money on a GT40 setup, why not get a nice EBC?
Old Sep 7, 2005 | 10:32 PM
darth fc3s's Avatar
thaks fellas . the reason im using a mbc is because im on a tight budget right now and the gt 40 turbo came with the car . but i figure right now i will use the mbc and if i need two step up to a ebc i can do it down the road .
Old Sep 8, 2005 | 07:25 AM
buttsjim's Avatar
Tight budget, eh? Well, this highly sophisticated unit is available at most auto parts stores, for less than a buck. An accurate boost guage is a highly recommended extra-cost option.
(don't flame me--I'm just kidding)
cristoDathird
28
May 30, 2019 08:47 PM
Wolf_
Aug 11, 2015 04:23 PM
