whats a good engine setup? S4 13bT 14psi?
Old Sep 6, 2005 | 11:13 PM
full-cruise's Avatar
D.I.L.U.S.I.
Well, I blew one of the rear seals. after talking to a friend about rebuilding with a large streetport running 14psi. im wondering whats needed to support this internally from what we came up with where thinking..
Mazdatrix full gasket kit
2 mm "RA" Apex Seals
solid corner seals
93 corner seal springs
new thrust bearings
To you guys that have been threw this and wanted to return with more potential power where the car is still street able but can hit the track for a few passes. Please post up what combination i could try to get her there. i would like to see mid/low 12's in a 1/4 mile pass on day.
other mods that i have done are in my signature.
Old Sep 12, 2005 | 11:44 AM
D.I.L.U.S.I.
thanks for the help..
Old Sep 12, 2005 | 11:48 AM
moehler's Avatar
Please make sure and research the RA seals. They are fairly controversial. I just put them in my engine and wont know how they worked out for a while.
Old Sep 15, 2005 | 08:19 PM
D.I.L.U.S.I.
Question
yea after digging around im going to leave the RA and atkins seals alone. im looking for 1 piece seals now but cant get them from the dealer. they dont carry them.
hey is your car at JPR imports? ? ?
Old Sep 15, 2005 | 08:20 PM
moehler's Avatar
Yep... it's the white FD.
Old Sep 16, 2005 | 02:22 PM
D.I.L.U.S.I.
.. keep it looking good . and good luck with it.
Old Sep 28, 2005 | 12:51 AM
GUITARJUNKIE28's Avatar
multipersonality disorder
ra's are fine for that hp level (draw your own conclusion as to whether r not you want to use them) i've got 12-15 motors withut a failure using those seals....as far as the whole thing goes, hell, a bone stock motor is fine for that hp level.
Old Sep 29, 2005 | 06:12 AM
RETed's Avatar
How much are you willing to spend???
-Ted
Old Sep 29, 2005 | 01:39 PM
gerbraldy's Avatar
wtf's a piston
BAM! The question that answers all.
Old Oct 12, 2005 | 02:39 AM
D.I.L.U.S.I.
Question
well im going at this as it comes, every part of this engine is getting touched with some of this sand some of that. its in the shop now getting 4 more strengthening pins installed making 8 all together. e-shaft is getting work along with the bearing and other lubrication mods 85psi OPR.
after reading i changed thoughts on the RA seals and went with mazda factory 2mm seals, S6 bearing and gears will be used i went with the ITO aggressive street port and RB exhaust port, upping the fuel injectors with the 720 seconds along with a parallel fuel system and paxton FPR. going to save up and get a standalone setup in there.
am i on the rite track so far for a strong motor?
Old Nov 10, 2018 | 08:11 AM
Dane Labuschagne's Avatar
I also need some help with my set up. But cant seem to get replys on my thread
Old Nov 10, 2018 | 10:22 AM
diabolical1's Avatar
Welcome to the board.
Your post count is 1, so that implies that you haven't made a thread here yet. Try going to the New Member section and posting an intro in the Intro section, then post whatever tech questions you have in the Tech section. I'm sure there will be people very willing to answer whatever they can for you.
Thanks,
Turblown
Aug 14, 2015 04:48 PM
Wolf_
Aug 11, 2015 04:23 PM
