second gear grind
Old Jan 17, 2002 | 06:34 AM
DONNA's Avatar
second gear grind
at first take off, 2nd gear wants to grind untill about the third time i shift and then works fine,,is there a fix for this...also, here is my daily driver..
Old Jan 17, 2002 | 08:38 AM
error402's Avatar
#!/sup_mod/üb3rg33k
if it makes you feel any better my 7 makes grinding noises in 1st, 2nd, 3rd and 5th gears. (but not 4th???). I straight piped my exhaust and now I can't hear the grinding because of the exhaust noise. LOL
Old Jan 17, 2002 | 10:32 AM
Denny's Avatar
Nice pic, Donna...Just have to change that car, Heh, heh, heh...
Just kiddin', it's a pretty Z type..
When you get a chance, get your Seven up into the air. Drain the trans oil, and while you're at it, drain the rearend oil too. Examine the drain plug. It's magnetic and will probably have a gunky residue around it. If you wanna you might shoot some brake/parts cleaner into the the fill and drain holes and see if anymore "gunk" drains out. Fill both the trans and the rearend with Synthetic Gear Oil. Brand is your choice, I use Mobil 1. Remember to fill to filler hole. Now I'm not going to say that this fixes all trans problems, but it's a good start, and it will help, not hurt. Check your clutch fluid level, and make sure your clutch slave cyl. is in good shape.
When it's cold outside I find my trans is a bit bulky at first, but once warmed up it's fine...Hope this helps.
Denny, from the 'ol corncrib...
Old Jan 17, 2002 | 04:47 PM
DONNA's Avatar
thanks for the info,,i dont recall it being this was during the warm weather,,,guess its another cold weather thing,,,
Old Jan 17, 2002 | 10:04 PM
Pele's Avatar
Right near Malloy
Donna's Synchro might be bad.
Error402's got a bad bearing.
Old Jan 18, 2002 | 01:56 AM
If it's hard to get into gear from a standstill odd's are it's in the clutch hyd. bad pilot bearing's can cause it also.If the trans makes no noise when in gear I would look more at aposs. hyd's prob.
MILOS7
Oct 9, 2015 02:19 AM
musker
Oct 1, 2015 05:58 PM
